Crank position sensorFieroBoy 10-22-2005, 10:19 AM Have you ever herd of one of these. i was told that i needed a new one. i have a 88 gt. i am getting a spark. it will sometime crank and turn over a couple times then die but most of the time it wont start. any ideas jamesggray 11-02-2005, 03:55 PM Sounds like a timing issue if you are getting a spark. Pull the distributor cap and check for cut or exposed wires on the pickup coil. When was the last time you drove the car? If it is the original engine then I doubt it has a crank position sensor. James Have you ever herd of one of these. i was told that i needed a new one. i have a 88 gt. i am getting a spark. it will sometime crank and turn over a couple times then die but most of the time it wont start. any ideas FieroBoy 11-03-2005, 01:15 AM i got the car not too long ago. it is parked because i am trying to do some stuff to it. I.E. new carpet A/C stereo and some body work. i baught the car with a 3.1 out of a camaro. i was told it could be that but i was thinking that maybe it was an o2 sensor. that is the sensor right before the intake manifold, it is duct taped around it and i need to replace the tubing. the car has been running the day before would it go out of timing like that? goatnipples2002 11-03-2005, 09:48 AM Our cars do not have crank position sensors or cam position sensors. Those are items for DIS. The later 60* v6 have these. Automotive Network, Inc., Copyright ©2012
