Headlights will not workplex4r 10-20-2005, 08:41 PM I started by replacing both lights. When this did not work, I purchased another set of lights. Next I checked the fuses by the door and in the main power fuses under the hood. All checked out ok. The brights work, but not the log beams. The park breaks also work. What could I check next to get my headlights working. Thanks, Bill. plex4r 10-20-2005, 08:42 PM Sorry I forgot to mention this is a 95 Ford Explorer EB. Bill. Jimmac 10-23-2005, 08:01 PM I had a similar problem with my 93 sport. I found that it had to do with the switch in the dash. See if when you turn it on, if the tail lights turn on as well as the dash lights. I found that through playing around with the switch i was able to find a weak connection(from wear) that i was able to make a temperorary fix for. The weak connection would only turn on the dash and tail lights. Try to turn the light switch on slowly to see if the headlights turn on briefly. If this is teh case, you most likely have teh same problem i did. Hopefully this helps, and good luck. Automotive Network, Inc., Copyright ©2012
