relly puzzled
tylercl
10-20-2005, 05:20 PM
i have a99 ford windstar runs perfect exept when running down the road it will make a loud squelling noise and then the van will shut down but it will crank right back up and run just fine the rest of the day engine light came on so i had it check on computersaid egr vale is bad so i replaced it with a new and reset the computer sure as i thought i got it fix when the engine light came back on agin took it back to the shop computer said i still had the same problem so im about to give up on it but its the wifes van so you all no how that gos . need help bad or never here the end of it
LeSabre97mint
10-22-2005, 12:02 AM
Hello
First off, what is the squell from? Belt? Possibly your alt is locking up.
I don't think the EGR valve will cause the engine to quit. The ports that lead to your EGR valve may be pluged with carbon giving you the EGR error. These trouble codes just point to the trouble. It doesn't always mean that the device is bad.
Any think else happening? Lights dimming?
Regards
Dan
rodeo02
10-22-2005, 10:50 AM
Do you have the a/c on or windshield defrost on when the squeal/stall happens? This sounds like a locked up a/c compressor. The serpentine belt squeals when the a/c compressor tries to engage. You can unplug the electrical connector to the a/c compressor to keep it from kicking on unti the issue can be looked into.
G/luck
Joel
wiswind
10-23-2005, 08:56 AM
How old is the serpentine belt?
Is the tensioner working correctly?
Did some fluid get onto the serpentine belt or a pulley?
EGR valve is not a high failure item....however, the DPFE (Differential Pressure FEedback)is a high failure item. This item has 2 hoses going to the metal tube that goes to the EGR valve. It is mounted very close (to the right and in front of) the EGR valve. You can easily replace it yourself.
