89 cherokee fuel injecting no 12 v powerkcar11705 10-19-2005, 09:43 PM Help Help Help First timer... I have a 89 cherokee pioneer that I had to put a fuel pump in. The old one was frose up but didn't blow a fuse since the new one runs fine. Now I have injector pressure of about 39 lbs but the injectors won't fire. Ground is on the injectors one wire as it should be but never gets 12 volts on the other to fire injector. The Electronic Control Unit has 12 volts to # 7 & 8. or at least is indicated their on the test plug. I pulled a fuel injector cap and hooked in a 12 v light in place of the injector which is suspost to flash when cranking the engine but it doesn't. Engine will start with starting fluid but will not run when injectors are suspost to do their thing. Any suggestionswould be appreciated. Please e-mail kcar11705@yahoo.com or post reply. 89ltd 10-19-2005, 10:07 PM you need a set of noid lights to properly test the injectors. 89ltd 10-19-2005, 10:12 PM are you sure you have 39 lbs at the rail when the engine is turning over? Automotive Network, Inc., Copyright ©2012
