Chrankshaft Position sensor removalkalabocca 10-19-2005, 07:17 PM What is the easies way to change the cps on an 89 cherokee limited 4L straigh 6?? runuover 10-21-2005, 10:35 AM [the best way is to get a swivel socket and dont drop the bolt in the bell housing as i did. its only 2 bolts its just hard to get to. good luck :slap: Saudade 10-21-2005, 12:14 PM And a few LONG extensions. Tie a long string to the connector before you remove it. When you get the new one installed, use the string to pull the wire harness back up. jdsalas 10-28-2005, 11:51 AM the swivel socket and a couple of 8 inch extentions. then come from underneath left wheel (from behind left front wheel). more easier for people with small arms. also my suggestion is to stick a crumble newspaper page right undernneath sensor to block the bolt from falling in the hole. I was lucky the magnet on the sensor was still strong enough to hold onto the bolt. I could see it already.... a simply replace job turn into a major tranny dropping job or something and all I am is a shade tree mach. Automotive Network, Inc., Copyright ©2012
