Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Dodge > Neon/Plymouth Neon > 1st Gen 95-99
Old 10-17-2005, 09:57 PM   #1
the_game_rock
the_game_rock's Avatar
the_game_rock Normal reputation
2.0 turbo vs 2.4 turbo swap
I have a 99 neon. What would be the best route to go? How much more horsepower would a 2.4 w/turbo have and how much faster?
the_game_rock is offline   Reply With Quote
Old 10-17-2005, 11:42 PM   #2
TEXSRT4
TEXSRT4 Normal reputation
Re: 2.0 turbo vs 2.4 turbo swap
the larger the displacement, the more power you can gain from a turbo. especially the 2.4 as opposed to the 2.0. turbos like a long stroke! you will be able to make more power over a broader power band!
TEXSRT4 is offline   Reply With Quote
Old 10-17-2005, 11:53 PM   #3
the_game_rock
Re: Re: 2.0 turbo vs 2.4 turbo swap
how much more power would the 2.4 have though?
Old 10-18-2005, 12:58 AM   #4
TEXSRT4
there are too many variables to say that off the cuff. i need compression ratios, boost levels, etc! expect it to make a significant amount more. hows that...
Old 10-18-2005, 01:00 AM   #5
TEXSRT4
you have more displacement, meaning more volume of air moving in and out. you can spool a larger turbo faster, meaning more air in and out again meaning more power! a long stroke is going to produce more torque lower in teh power band. if your limiting yoruself to pump gas, the 2.4 will be the way to the most power!
Old 10-18-2005, 11:32 AM   #6
neon_rt
neon_rt's Avatar
neon_rt Normal reputation
Is your 2.0 a SOHC or DOHC?
neon_rt is offline   Reply With Quote
Old 10-19-2005, 11:07 AM   #7
the_game_rock
dohc
Old 10-19-2005, 11:34 AM   #8
neon_rt
neon_rt's Avatar
You could start by transplanting a 2.4 into your Neon, tuning it up some and then decide if you need more speed. 2.4s seem to respond better to turbo than the 2.0. You would get more HP per $ if you turbo the 2.4.
Old 10-23-2005, 02:23 AM   #9
SkylineMan32
Banned
SkylineMan32's Avatar
SkylineMan32 Normal reputation
Send a message via AIM to SkylineMan32 Send a message via Yahoo to SkylineMan32
The SRT-4 Dyno's in at roughly 200HP @ the groun, on a DOHC 2.4L. So at similar boost on a stock 2.0L i dunno 170-180?. However TEXSRT4 is right it is hard to just pull numebers out of the air. With your older 2.0 you need to lok out for the strength of your internals probably aren't 20psi ready.
SkylineMan32 is offline   Reply With Quote
Old 10-23-2005, 02:10 PM   #10
TEXSRT4
the srts dyno in at 230hp and 250ft/lbs of torque stock. so thats more than normal boost levels on a stock 2.0. but can take 500 (if tuned right) on stock internals! so you wont have to build anything. just add more boost. otherwise you will have to build your 2.0
Old 10-23-2005, 02:11 PM   #11
TEXSRT4
those numbers are at the tires
Bookmarks
Google
Web AF
