95 grand am starter
dorkymonkeyhxc
10-17-2005, 08:19 PM
i want to install a new starter on my car. i wanted to know how i can go about taking it out and what i should be looking for.
dorkymonkeyhxc
10-17-2005, 08:22 PM
by the way it is a 1995 grand am gt 4 dr with a quad ohc engine 4 cylinders
skibum1111
10-17-2005, 08:32 PM
Welcome. The starter on the quad motors is a miserable job. Its under the intake manifold. The bolts go into it from the transmission end, they aren't too difficult to get to. Getting the starter out involves some logistical planning, you have to twist it around to get it to clear the intake, engine block and radiator, it comes out the bottom of the car and goes back in the same way. Good luck.
dorkymonkeyhxc
10-17-2005, 08:44 PM
i'll give it a try thanks for your help.
skibum1111
10-17-2005, 08:48 PM
Not a problem. If you run into problems getting it out or putting it in just post, someone is usually around who has had the same problem.
dorkymonkeyhxc
10-18-2005, 05:13 PM
i've taken out 2 of the bolts but i'm stuck on the third. i just cant seem to get to it. i took out the master bolt and one of the supporting bolts. the one i can't get to is the one that is under the intake manifold. any tips on what tool i should use or how i can go about finishing taking it out. i'm really stuck on this one. .
