Question regarding 1990 5SFE Celica's power steering pump!
vi3t1uv
10-16-2005, 03:07 PM
Hi there, i just got done switching the power steering pump, cause the old one was bad. After i put the one on, i found out that it's leaking from the pressure line (at the end, where the fitting and bolt goes in)
Now, that i know it's better to reuse the fitting that i already had on the old one, but that fitting didn't fit into tha new one so i just have to use the new fitting, is that the reason why it leaked???? I need some advice or suggestion. Thank you!
jerryls
01-22-2006, 10:13 AM
I;m having a pressure hose problem also. You probably fixed it by now, but question -- how did you remove the pump. I cant get at the upper mounting bolt form the bottom.
Thanks for any advise
Jerry
never2nd
02-11-2006, 02:37 AM
You need skinny arms and long fingers but you can reach it from below with an open end wrench, turning the bolt about 1/4 revolution at a time. Did you remove the bottom crossmember? Gives you more room under the car.
jerryls
02-13-2006, 11:18 AM
Thanks, Got it done and no leaks! I wouldnt want to do it again. Yes i removed the cross memeber. I found it easier to take off the pump to get at the hose connection
