'95 SC2 EGR Valve
mcjim
10-16-2005, 11:35 AM
Hello I need to know where the EGR-Valve is located and also can it be cleaned to make it work again or does it have to be replaced and how much does it usually cost ? Thanks for any info. Jim
stevestar99
10-17-2005, 07:48 AM
There should be a data plate on the radiator cross beam that shows the location. On the SL1, it's on the driver's side, mid-block, under air intake duct, looks like an OJ can with a wire harness connected to it's top.Yes, the air ports and valve seat can be cleaned out for the carbon build up.
sierrap615
10-17-2005, 08:49 PM
on the 95 sc2, it is directly to the right of the oil filler cap, its a tall black cylinder. clean it with carb and choke cleaner and replace the gasket
mcjim
10-18-2005, 11:31 PM
Thanks Guys for the replies I will check it out this coming weekend. Jim
