Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 10-15-2005, 09:20 PM   #1
Elbert
Elbert Normal reputation
Front Diff 92 K1500
Anyone know what the difference between K1500 and K2500 in the 1992 year model range? I own a 92 K 1500 and was wondering what the difference in the mounting of the front differential is between these two trucks. I assumed they were very similar.
Can you swap a 2500 front differential into a 1500 truck along with the cv joints?
Also anyone know of a limited slip type differential or electric or air locker that works or fits a 1992 K1500. I've hear also the the Detroit Truetrac is a good setup for the front end but I don't think anyone makes anythging for a 1500 series truck.
Any comments? Email at elbert.clarke**@adelphia.net if you want or post here...I'm new to this forum, I'll try to check it regularly...I do post on the alt.chevy4*4 newsgroup. Remove the ** to email.
Elbert is offline   Reply With Quote
Old 10-16-2005, 09:35 PM   #2
dawnnewsome3
dawnnewsome3 Normal reputation
As for mounting they are the same,but be warned when changing chunks "aka diffs" always check the gear ratio to be positive it is the exact same as the rear . If not major damage can accure,as for lockers they're many oppsions.
dawnnewsome3 is offline   Reply With Quote
Old 10-17-2005, 08:11 PM   #3
Elbert
Re: Front Diff 92 K1500
I'm looking for a K2500 front differential because as I understand it the 2500 is a 9.25 differential and the 1500 is a 8.25 differential. Eaton makes an e-locker for the 9.25 and no-one makes any type of posi unit for the 8.25.
I'm wondering if it truely is a simple bolt in replacement?
I'm aware of the need to match the gearing front to back.
ANyone done a swap like this?
Bookmarks
Google
Web AF
