94 PF 4WD M/T shutting off while drivingphantastic1 10-14-2005, 01:37 PM it started off as a starting problem. i've had the starter replaced and tuned it up (cap, rotor, plugs, and fuel filter). starts better now....but now the problem is that while im driving...it will shut off on my. i've only noticed it shut off when i'm turning left. it has done it about 4-5 times now. driving straight...i havent noticed a problem. it hasn't shut off on my turning right. once it shuts off...i would have problem starting it again....i would have to jump it. if i shut it off myself and start it back up....it will start. any help will help. phantastic1 10-17-2005, 05:12 PM ***UPDATE*** I found out that I lose spark whenever it dies out. That would explain the shutting off problem. However, I have replace both the ignition control module and the ignition coil...and it will still die out. I'm starting to assume it may be the ECU. Does nissan have any common problems w/ PF ECU's? denisb 10-18-2005, 12:01 PM Try posting this on http://npora.ipbhost.com/ I beleive I've seen a problem similar to this on this site. Denis phantastic1 10-18-2005, 01:11 PM thanks...i'll give it a shot Automotive Network, Inc., Copyright ©2012
