Originally Posted by sheetmagnet
Would he need to replace his injectors, fuel rail, and go with an updated ECU program, or could the neon ECU and hardware be able to handle the boost on it's own?
The injectors would need to be upgraded to at least 24lbs., the stock fuel rail works great, a better fuel pump (a walboro 255 lph would do), your stock ECU will work but you need a Voltage clamp or Missing link to work with it. You can put on an MSD ignition also.
Originally Posted by the_game_rock
what else would I need to finish it?
Everything that I mentioned above and:
*probably a bunch of fittings and clamps
*I would run an intercooler with it, so you would need that and the piping
*Plumbing for the turbo, some turbos are just oil cooled and some are also water cooled
*RRFPR
*Return line. Your car doesn't have one so you need to find a way make one.
There is some stuff I may be forgetting, but that is all I can think of right now.
