Honda Pasport missing in 2 cylinders
yobwoc
10-13-2005, 02:46 PM
the Pasport misses on the left middle cylinder the right rear Cylinder it is getting fire but no gas but when we checked the injectors they are working. any help appreciated
rodeo02
10-13-2005, 07:57 PM
1997? Sounds like your valve timing jumped. To check this, you will need to run a compression test and verify cam lobe position in relation to crank position.
G/luck
Joel
yobwoc
10-13-2005, 08:49 PM
G/luck
Joel
Joel thanks for your input I we checked the compression and it was good on all cylinders
Canucklehead
10-13-2005, 09:01 PM
Have you tried swapping the injectors from the "bad" cylinders into two other cylinders? Same thing with the coil-packs... etc.
yobwoc
10-13-2005, 11:49 PM
No I haven't swapped the injectors yet that was the next thing we were thinking about, if it work I will let you know .
thanks for the input
