what does check gages light mean?Petertrack 10-12-2005, 07:58 PM I have a 96 blazer LT with about 140,000 miles on it. my check gages light came on about 3 days ago. there is a funny smell coming from the engine and a little smoke when I pop the hood. It also has little jerks or surges when I drive it. I know for a fact my air filter is filthy and I have just been lazy about changeing it but something tells me it bigger than just my air filter. Any ideas what it is and how to fix it? Is it my transmission? BlazerBoyLT98 10-12-2005, 08:36 PM I have a 96 blazer LT with about 140,000 miles on it. my check gages light came on about 3 days ago. there is a funny smell coming from the engine and a little smoke when I pop the hood. It also has little jerks or surges when I drive it. I know for a fact my air filter is filthy and I have just been lazy about changeing it but something tells me it bigger than just my air filter. Any ideas what it is and how to fix it? Is it my transmission? Check gauges or check engine? Or SES (service engine soon)? JC327 10-12-2005, 11:05 PM Check guages light comes on if you are overheating, have low oil pressure, low voltage, etc. It is alerting you to look at your guages and see what is wrong. From what you are saying, it sounds like you are probably overheating. Check your coolant and your oil. Don't drive around like that or you won't have an engine left to repair. wolfox 10-13-2005, 12:24 AM The check gages light will come on when there is an anomalous reading in the analog dials in the dash. Mine lit up and a quick glance down showed a mild overheat. This was about 3-4 months ago when my lower intake seals went and it got low on coolant. Like JC327 said, when the gages go wacky on you or read high or low, that will light up to draw your attention. Petertrack 10-19-2005, 04:35 PM Check guages light comes on if you are overheating, have low oil pressure, low voltage, etc. It is alerting you to look at your guages and see what is wrong. From what you are saying, it sounds like you are probably overheating. Check your coolant and your oil. Don't drive around like that or you won't have an engine left to repair. Thanks for the help guys. it was my coolent, cause it was low but I guess that means I got a leak somewhere. herkyhawki 10-19-2005, 10:57 PM what does check gages light mean?.\ That light means you should check your gauges. BlazerLT 10-19-2005, 11:03 PM \ That light means you should check your gauges. Which means one of the following: Fuel Level is low Volt Gauge Reading WEird Engine is Overheating Oil pressure is low You should be paying more attention to this, that smell was you engine overheating and the temp gauge will have to be high for that to happen. Pay attention mopre next time and actually CHECK THE GAUGES. DINO55 10-19-2005, 11:32 PM Hey peter, If you overheated your truck, Change you Engine oil and filter ASAP. BlazerLT 10-19-2005, 11:37 PM Hey peter, If you overheated your truck, Change you Engine oil and filter ASAP. Why? DINO55 10-19-2005, 11:56 PM Because after the Oil temp reaches around 250F it has begun it's break down. BlazerLT 10-20-2005, 03:50 AM Because after the Oil temp reaches around 250F it has begun it's break down. Nah, it is made to withstand much higher temps than that. DINO55 10-20-2005, 05:56 AM Hmmmm, I did not know that. BlazerLT 10-20-2005, 05:45 PM Hmmmm, I did not know that. No problem, an oil change is only necessary if coolant gets in the oil. Automotive Network, Inc., Copyright ©2012
