still no turn signal 98 taurusurlacher5476 10-12-2005, 09:42 AM im having trouble locating the relay but i have no turn signals or hazards at all. the lights on the dash dont come on and there no clicking either. ive heard there is something called a flasher in the dash or under the hood. is this true and could this possibly be the problem? if so does anybody know where the flasher is located? thank you for any help! denisb 10-12-2005, 11:28 AM If there is a flasher, it's usually located on the fuse panel and round in shape. However a lot of newer cars do not have flashers any more........not sure about the Taurus. I'll check on mine tonight and let you know. Denis urlacher5476 10-12-2005, 01:40 PM cool thanks alot. if not any clue what else it could be? ive been told the relay but im not sure which relay is for the turn signals fuba 10-14-2005, 09:17 PM It's almost directly behind the emergency brake release lever. It's just above and inboard of the release cable as it comes through the back of the dashboard. To access it: Remove the 4 #30 torx screws holding the dash cover plate that is directly below the steering column in place. You can now see the flasher, by looking from that panel in behind the emergency brake release handle. To actually get a hand on it, and release it from its bracker, I had to lay in the drivers seat with head down at the pedals. Put the emergency brake on, so your right hand can reach up behind the release level from below. Your left hand can get two fingers through the access panel you removed to stabilize the unit as you push it off the bracket. Automotive Network, Inc., Copyright ©2012
