S40 Vibration
skate6koz
10-11-2005, 09:31 PM
I am having a problem with the 2000 S40 vibrating when accelerating. We have changed all four engine mounts and the driver's side (left) axle. The passenger (right) side axle seems fine. It shakes really bad at higher speeds, like 50mph, but doesn't vibrate when you let off on the gas. The car has 110k miles, but is in very good condition. Has anyone experienced the same issue ?
volvopain
12-20-2005, 03:11 PM
I have the same problem. S-40 with 99,000 miles. vibrates on acceleration especially when warmed up. Runs smoothly when you let off the gas. Also has slight left pull, but gets more severe when accelerating. Motor mounts have also been changed. axles and joints checked by mechanic who says they look good. Has had 3 new alloy wheels and new michelin tires. Any ideas?
volvopain
12-21-2005, 09:55 PM
Two days later I have found my S-40 vibration problem. Right axle assembly. found tulip (plunge) joint worn. lot of play in the joint. Replaced entire axle assembly (from volvo parts). runs great.
hocbj23
04-13-2006, 02:02 PM
Check tranny mount. Have been known to have problems and cause the symptoms cited above. BJ
