dash& tail lights outalknut 10-11-2005, 01:50 AM i have a 93 jgc , my interior dash , heater , and tail lights are out but when i step on the brake or turn signals they work . i checked fuse 24 ( 7.5) for instrumentation lights fuse is good but no power there . I need somme help . thanks BOEW 10-11-2005, 02:07 AM Check The Main Wiring Block Where It Comes Through The Firewall. Chrysler Vehicles Were Noted For Having Problems With One Or Two Of The Main Hot Wires Having Bad Connections Due To Water Or Corrosion. You Will Have To Separate The Main Bulk Head To Find It. You Should Do A Shake Test On The Wire Harness Under The Dash In And Around Where It Come Through The Firewall And Connects To The Main Harness Under The Dash. You Will Find It For Sure Just Take Your Time And Don't Shake The Crap Out Of It Just Move It Around A Bit. Ron Automotive Network, Inc., Copyright ©2012
