jdm h22a swap into 97 civic exforcefedcivic 10-11-2005, 12:50 AM doing jdm h22a obd1 into 97 civic ex with hasport mounts using p13 ecu and hasport jumper harness. need help on wiring obd1 to obd2 everything is taken care of on the ecu plugs bc jumper harness but having trouble with the egr valve can you bypass this bc there is no plug for it on the ex harness or does this have to be wired in and also there is no crank position sensor on the obd1 motor. and the two hardlines that are cut on the back of the trans. are these used or no?also do you need the lift valve selenoid bc the plugs are diff. Automotive Network, Inc., Copyright ©2012
