'88 trooper thermostat questionLMT32 10-10-2005, 11:01 PM I have an '88 Isuzu Trooper with a 2.6Liter 4 cylinder engine and when the engine is cold and I drive it for about 4 or 5 minutes, the temperature gauge nearly points to the "H" position before it starts going down to normal pointing straight up at the very center between "C" and "H". Is this a sign of a weak thermostat or is this just normal for a 4 cyinder engine? Hollowcreek 10-11-2005, 04:40 PM Has the water pump been replaced? LMT32 10-11-2005, 08:22 PM No, I haven't replaced the water pump in the 6 years I had it. But how can the water pump be bad? After the thermostat kicks in, the temperature returns to normal and stays that way down the road. Hollowcreek 10-12-2005, 05:41 PM By virtue of the fact that it cools down at a certain point, the thermostat is opening, eventually. Try a thermostat first, but I ended up having to replace the WP. My overheating was being caused by lack of sufficient circulation due to a shot pump and exhibited the same symptoms. 89trooper 10-29-2005, 07:14 AM Yes it is a weak water pump. Also replace the thermostat and flush the entire system when you do it. Automotive Network, Inc., Copyright ©2012
