cost to replace bag ignition switchCAPT703 10-10-2005, 12:05 PM I was just quoted a cost to have the following replaced at my GM dealer 1). Replacing bag ignition switch 2). Replacing drivers door hinge pins and bushings ( quoted $100.00 ) total cost is $432.35 I live in CT if that makes any difference on how the cost is determined thanks Stephen mike2004tct 10-10-2005, 01:12 PM I was just quoted a cost to have the following replaced at my GM dealer 1). Replacing bag ignition switch 2). Replacing drivers door hinge pins and bushings ( quoted $100.00 ) total cost is $432.35 I live in CT if that makes any difference on how the cost is determined thanks Stephen Had my switch replaced last year. It cost $125.00 for the part from a GM dealer, plus 2 hours labor and 1 hour diagnostics @ $60.00/hour (discount thru the company I work for). I just bought a new switch at Autozone last week for $89.00 (The same exact unit that Chevy sells). It took me 1.5 hours to replace it. Gabe25 10-10-2005, 01:56 PM I replaced my 96 Blazer Ingnition Switch. Paid $76.00 from Redline Auto Parts (Which is Delco Parts). Took me about 1 1/2 hours to replace. Its really not that hard to replace. The only problem I can think of that you mite run into is the 2 screws that hold the Ignition Switch to the Ingnition key assembly. I had Male Torx screws holding it in place. Luckly I have a set of Male & Female Torx sockets. The rest of the replacement of the harness is easy. mike2004tct 10-10-2005, 03:28 PM The only problem I can think of that you mite run into is the 2 screws that hold the Ignition Switch to the Ingnition key assembly. I had Male Torx screws holding it in place. Luckly I have a set of Male & Female Torx sockets. The rest of the replacement of the harness is easy. E4 Torx socket, lisle makes a long shank socket specifically for GM/Cadilac distributor/coil removal. Also needed an E6 socket to get the top sterring wheel cover off, put a needle nose pliers will work. DINO55 10-10-2005, 05:42 PM CAPT703 Replacing drivers door hinge pins and bushings ( quoted $100.00 ) I just replaced the hinge pins/bushings on both my front doors. Cost me...$20.00. We have a sticky on how to do this yourself. Automotive Network, Inc., Copyright ©2012
