Originally Posted by element4ever87
the NGC is called the next generation computer and people have told me that it adapts do mods to limit your peak hp output
Okay, got it. I know the new computer "thinks" much faster than the older ones, but it can't defeat some mods. For instance, if you add a custom cold-air kit to your car like a K&N FIPK2 kit, the motor will breathe more air and will have to implant more fuel into the air charge in order to avoid running to lean... thus, more air and fuel = giddyup.
** At 400 miles, I bought a new K&N air filter, cut an additional hole in the end of it and added another filter element to it (even more surface area, less restriction) then installed it in the OEM box.
** At 1500 miles, I removed that huge bulky/worthless resonator that connects to your filter box through an elbow from the inside of the fender-well. It doesn't serve much purpose, except making the intake "quieter" and it restricts airflow. So I yanked it and tossed it.
** At 1800 miles, I changed the oil and went with full synthetic (Always Mobil 1 except one time, when I tried Royal Purple) and plan to always run full synthetic in the motor.
** At 10,000 miles, I cut another hole into the bottom of the filter box, and connected an additional 2 1/2" pipe out the bottom and ran it to the bottom of the car, underneath and slightly in front of the radiator, insulated in a kevlar weave (more cold air, less restriction at WOT.)
** At 10,000 miles, I painted the airbox bright yellow to match other dress-up things I did under the hood... but bright yellow refelects heat better than standard black anyway, so the theory is that this helps maintain a colder, denser air charge.
** At 11,000 miles, I used corrogated plastic sheeting to fabricate a "scoop," if you will, to direct cool air from the front and bottom of the car up into the fender-well to the main air intake tube.
** At 2000 miles, I yanked the exhaust from the rear tires on-back, and installed a custom 2 1/2" exhaust with a 30-series Flowmaster. Sounds unique (NOT like a fart-can), and is less restrictive than the OEM muffler.
** At 13,000 miles, Installed Bosch +4's. I know there is a lot of controversy over spark plugs in a neon and this is one of them. Some people love them, some people hate them... I personally was pleased with the swap.
** At 11,000 miles, I threw a 4.7k-ohm resistor inline with the IAT, and started running 89 octane instead of 87... this is probably the most controversial "cheap mod," because the computer WILL try to defeat the IAT modification at some point... Long story short, I have had success with it (on this car, anyway). There are more specifics but I won't go into detail unless someone asks (thank God, right? he he).
Anyway that's what I have done... I have 17k miles on my car and I can scoot from 0-60 pretty quick. No 1/4-mile time at the track yet, but it's definitely much peppier than when I bought it new. The torque-curve seems flatter, but higher... The 1-2-3 shifts come pretty quick at WOT.
