JDM b18c TURBO helpskiclouds 10-08-2005, 05:55 AM I want to make my B18c turboed, but i dont know what i would need to repacle to run 20 psi or to get around 300hp. i am probably getting a T3/T4 turbo or a 14B. can i still run vtec if i turbo the car? would 440cc injectors be good enough. what pistons and rods would i need. would need to replace the cams, or cam shaft? any help is needed thanks. superbluecivicsi 10-08-2005, 12:43 PM 20 psi is a meaningless number. here you go sir. http://www.beesandgoats.com/boostfaq/g2icturbo.html Schister66 10-09-2005, 12:41 PM You need to read that site and learn....i still think that site should be on a sticky at the top of this whole forum!!!!!!! forcefedcivic 10-11-2005, 01:04 AM I want to make my B18c turboed, but i dont know what i would need to repacle to run 20 psi or to get around 300hp. i am probably getting a T3/T4 turbo or a 14B. can i still run vtec if i turbo the car? would 440cc injectors be good enough. what pistons and rods would i need. would need to replace the cams, or cam shaft? any help is needed thanks. you would have to build your whole motor from pistons, rods, to head work and full fuel system mods probably bigger than 440cc injectors i was using 440s on my turbo sohc motor built with aem standalone ecu oith t3/t4 to many mods maybe even want to sleeve it. was running 15psi civickiller 10-12-2005, 12:41 AM 300whp. you could keep it stock. but i would recommend changing your pistons, everything else should handle 300whp. or just run your stock pistons till you blow the motor then swap pistons. Automotive Network, Inc., Copyright ©2012
