My 1998 Beretta will not startBob6800 10-07-2005, 03:32 PM Battery checks good. Engine will not turn over fast enough to start. Have tried 2 new starters cleaned the ground wire and engine still barely turns over. Any help appreciated. michelq 10-09-2005, 06:02 AM Battery checks good. Engine will not turn over fast enough to start. Have tried 2 new starters cleaned the ground wire and engine still barely turns over. Any help appreciated.if it is a good starter and battary cable good as you say then i would replace the battay,try to boost it from another car and see what happen C95TSI 10-18-2005, 09:06 AM Did you mean to say 89 or cavalier they didn't make them 98? I got confused but did you get the alternator checked? catprotector 10-28-2005, 05:48 PM If the battery is good and you have replaced the starter then it could be the alternator. kok328 10-28-2005, 07:03 PM The alternator doesn't come into play until after the car has started so it can't be that. Take the starter out and activate it with a pair of jumper cables directly from your battery and see what happens. Also, how do you know for sure that your battery is good. A 12.5 - 13V DC reading does not necessarily mean the battery is good! route89 11-02-2005, 09:33 PM Battery checks good. Engine will not turn over fast enough to start. Have tried 2 new starters cleaned the ground wire and engine still barely turns over. Any help appreciated. Sounds as though something is dragging? Perhaps your alternator is frozen up? Loosen your alt belt and check to see alt turns freely. Do your headlights dim, or does your pos cable get hot when cranking it over? (Sugestions) Starter may need to be shimmed away from flywheel? If starter is to close it could bind up. Did this car sit for a long period without being turned over, perhaps the cylinders got rusted? Pull your dipstick, are there any small metal particles in your oil? Perhaps engine has a bad rod or main bering causing excessive drag? Turn engine over by hand or with a ratchet and socket on the end of the crankshaft. anomaly_va_1976 01-25-2008, 11:43 PM A/C compressor could be seizing... my 90 Lumina (3.1) did this and got to the point where it flat would not crank.... good battery and starter.. '97ventureowner 01-26-2008, 12:07 AM Old thread, please do not bring up old threads past 90 days since last posting activity. Closed. Automotive Network, Inc., Copyright ©2012
