still need help with temp gauge...jwendell 10-07-2005, 12:10 PM i have a '96 JGC laredo, 5.2 V8, my temp. gauge reads the maximum all the time even though my engine isn't overheating, this causes my "check gauges" light to appear. this also causes my interior lights to blink noticeably when driving at night. i no longer have delay on my windsheild wipers. one time when i was driving the alarm starting going off, but that only happpend once. i have replaced the coolant/temp. sensor and that didn't fix the problem. after i replaced the c/t sensor, the "check engine" light appears but shuts off after a few miles. i've already tried turning my key on/off three time and leaving it on "on" on the 4th attempt to have my computer let me know what's wrong, but that didn't work??? also, my computer doesn't tell me that anything is wrong, i read in a thread that the computer should tell me a sensor is bad. is my computer going to hell?? does anyone have any idea to what may cause my guage to read faulty temps? thanks for the advice!! jw later that day.... i hooked up an OBD II to it and it read P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High Voltage". is this simply telling me what my gauge is telling me? any ideas on how to fix this error??? thanks... PROBLEM SOLVED after some time and convincing the dealer to actually try even though they said it wasn't the problem. the body control module (BCM) fixed this problem. don't let the dealers try and tell you it is something else, they tested my BCM and said it was fine. i really had to persuade them to try a different BCM. this is something you can actually replace yourself, the BCM was under the steering wheel on my '96. thank you to everyone who participated in this discussion. jw 89ltd 10-07-2005, 04:24 PM how do you know the engine is not overheating? Does the temp gauge go to the top as soon as you start the jeep? larrydm 10-08-2005, 12:29 PM Hi I have the exact same problem on my 1997 JGC 4.0 6 cyl and as yet have not figured it out. I was hoping for some advice. My dome lights and wipers are doing the same as yours. My local Chrysler dealer put my jeep on the computer and told me it was my instrument cluster. I replaced it but the temp guage still goes to max temp as soon as you start the engine. I checked for PCM codes and got the same message as you- code 22 which indicates an over or under voltage from the temp sensor. I Ohmed out the sensor and it is well within the specs when cold and at running temp of approx. 210 deg. I am getting 5.14 volts supplied to the temp sensor. Specs call for approx. 5 volts. Is the .14 enough to give the error? At this point, I'm stuck and could sure use some help as to what to try next. I considered the power train control module but all my other controls seem to be working well. Thanks jwendell 10-09-2005, 03:24 PM how do you know the engine is not overheating? Does the temp gauge go to the top as soon as you start the jeep? yes, it goes to the top immediately after i start my jeep. it even goes to the top when i turn my key on the 'on' position when it isn't started. jwendell 10-13-2005, 10:06 AM Hi I have the exact same problem on my 1997 JGC 4.0 6 cyl and as yet have not figured it out. I was hoping for some advice. My dome lights and wipers are doing the same as yours. My local Chrysler dealer put my jeep on the computer and told me it was my instrument cluster. I replaced it but the temp guage still goes to max temp as soon as you start the engine. I checked for PCM codes and got the same message as you- code 22 which indicates an over or under voltage from the temp sensor. I Ohmed out the sensor and it is well within the specs when cold and at running temp of approx. 210 deg. I am getting 5.14 volts supplied to the temp sensor. Specs call for approx. 5 volts. Is the .14 enough to give the error? At this point, I'm stuck and could sure use some help as to what to try next. I considered the power train control module but all my other controls seem to be working well. Thanks well i've tried fixing this problem on my own, replacing the sensor, checking voltage and resistance, and i even replaced the thermostat (which was broken when i took it out). i thought for sure that that was the problem, but the temp gauge still maxes out. time to bring it to the dealer. do you remember how much the instument cluster cost?? I really don't think that a .14 voltage would cause your temp gauge to max out, like you said, specs say aprox. 5 volts. if you have any other ideas please share them. thank you. larrydm 10-13-2005, 01:42 PM well i've tried fixing this problem on my own, replacing the sensor, checking voltage and resistance, and i even replaced the thermostat (which was broken when i took it out). i thought for sure that that was the problem, but the temp gauge still maxes out. time to bring it to the dealer. do you remember how much the instument cluster cost?? I really don't think that a .14 voltage would cause your temp gauge to max out, like you said, specs say aprox. 5 volts. if you have any other ideas please share them. thank you. I paid 50.00 from a salvage yard so I suppose it's possible that they could have given me one with the exact same defect but I doubt it since my Chryslwer dealer said that they have never seen an instrument cluster have a bad temp guage. Me dealer quoted me 180.00 for a brand new one and you have to purchase it through a dealer. I may go back to the salvage yard and get a different cluster and try that just in case. Thanks glass 10-13-2005, 08:40 PM just a guess... but could there be a short in the wires going to the temp gauge ?? JDPascal 10-13-2005, 11:18 PM Hi jwendell and larrydm The instrument clusters on these models are a computer by themselves and operate by talking to the powertrain control module thru something called the CCD BUS. The cause of your problem could be with anything that uses the CCD bus system. Connectors that have extra resistance, aftermarket installs that have been crossed with CCD wiring or just bad connections in that circuit or a bad PCM with old programming and circuitry. Your sensors, computers and instrument cluster could be fine but still have a temp gauge problem or a whole instrument cluster showing no or bad readings. Check with the dealer to find out if there is a newer version of your PCM available. There is a number on the PCM to identify it and sometimes a sticker on the hood to show if it has been changed and when. I know that mine was updated before I purchaced the vehicle. Hope I explained this right. I'm only useing words and explaning it how I understand it (which isn't very deep). What you are likely looking for is a technician with a good electronics background to trouble shoot it. Sorry if this is not an encouragement to you. :uhoh: JD jwendell 10-14-2005, 11:14 AM just a guess... but could there be a short in the wires going to the temp gauge ?? there could be i guess. i checked the voltage coming out of the temp/coolant sensor and it was between 4-5, i know 5 is average but if it is lower it wouldn't cause the gauge to max out. if there was a short, would there be an voltage? or how else would you detect a short? i am going to replace the sending unit today. i'll post back later with the outcome. thanks for all the replies... xj31 10-14-2005, 10:01 PM I have seen this before and it was actually the body computer.I still have no idea how because according to schematics,it is not supposed to have anything to do with the temp gauge.I had the luxury of an identical jeep to swap test parts from.The bcm was just a guess after trying the sensor,gauge and pcm. smichael 10-19-2005, 09:28 AM try disconnecting the connector to the thermostat and start the car-see what the gauge reads jwendell 10-19-2005, 09:32 AM try disconnecting the connector to the thermostat and start the car-see what the gauge reads do you mean disconnect the connector to the temp. sensor?? i've tried disconnecting from the sensor and still reads high. I was also told that if i turn the key on without starting and the gauge reads high, the thermostat has nothing to do with it...thanks smichael 10-19-2005, 09:32 AM try disconnecting the connector to the thermostat and start the car-see what the gauge reads-if it zeros, the car will zt least run. if it still max's out-then the gauge is getting input from a second source- a short? jwendell 10-19-2005, 01:51 PM I have seen this before and it was actually the body computer.I still have no idea how because according to schematics,it is not supposed to have anything to do with the temp gauge.I had the luxury of an identical jeep to swap test parts from.The bcm was just a guess after trying the sensor,gauge and pcm. is there anyway to test the body computer? it's been at the dealership for 1.5 days now and they still cannot figure anything out! smichael 10-20-2005, 09:41 AM sorry - meant the temp sensor. I had a similar prob with a 93 gr chkee the gauge would read zero intermittently. I did try changing the sensor but it made no difference. My prob was less bothersome since it read zero instead of hi- it still does this but very infrequently(occurance has leesened,but don't know why)-not enough to waste money having a dealer try to solve it. do you mean disconnect the connector to the temp. sensor?? i've tried disconnecting from the sensor and still reads high. I was also told that if i turn the key on without starting and the gauge reads high, the thermostat has nothing to do with it...thanks smichael 10-20-2005, 09:47 AM After replying I remembered something else. I had this problem for a long time, and early on a mechanic convinced me to change the computer- at first i thought he fixed it, but because it was intermittent-I was wrong - it show back up after 6 months-don't know why it took 6 months to reappear but after that it would happen about once per week in summer and once per month in winter- heat seemed to increase the frequency of the problem. is there anyway to test the body computer? it's been at the dealership for 1.5 days now and they still cannot figure anything out! xj31 10-23-2005, 01:57 PM is there anyway to test the body computer? it's been at the dealership for 1.5 days now and they still cannot figure anything out! The only way I figured it out was to take the bcm out of another car and try it.You gotta be careful if one has theft alrm and one doesn't then don't do it or the other bcm can "learn"that it should have theft alarm. mdfranci 10-27-2005, 08:01 AM I was reading through this thread and I wanted to ask a question. My daughter has a 94 Grand Cherokee and the gauge reads zero all the time now. I pulled the connector off the thermostat housing and it read 4.97 volts which is ok and I plan to pull the sensor out and do the resistance readings I read in the manual where I put it in water at different temperatures to see if the sensor is bad. The question is, if the sensor is good and the gauge is bad I was planning to put in an aftermarket water gauge in but does the aftermarket gauge just plug into the sensor already there or is there a sensor that comes with the gauge. I was not sure how this works and I wanted to see if anyone out there can explain this a little more to me. Thanks, Mike Francis smichael 10-27-2005, 01:11 PM I had that problem on a 93 gc . it was intermittent, and the problem eventually went away-don't know why. But when it was happening, I did test the sensor in hot water and it read ok- resistance changed with temp. I still tried changing the sensor-it did not solve the problem. In the end, with the old sensor-the problem just disappeared. I was reading through this thread and I wanted to ask a question. My daughter has a 94 Grand Cherokee and the gauge reads zero all the time now. I pulled the connector off the thermostat housing and it read 4.97 volts which is ok and I plan to pull the sensor out and do the resistance readings I read in the manual where I put it in water at different temperatures to see if the sensor is bad. The question is, if the sensor is good and the gauge is bad I was planning to put in an aftermarket water gauge in but does the aftermarket gauge just plug into the sensor already there or is there a sensor that comes with the gauge. I was not sure how this works and I wanted to see if anyone out there can explain this a little more to me. Thanks, Mike Francis jwendell 10-29-2005, 01:25 PM Hi I have the exact same problem on my 1997 JGC 4.0 6 cyl and as yet have not figured it out. I was hoping for some advice. My dome lights and wipers are doing the same as yours. My local Chrysler dealer put my jeep on the computer and told me it was my instrument cluster. I replaced it but the temp guage still goes to max temp as soon as you start the engine. I checked for PCM codes and got the same message as you- code 22 which indicates an over or under voltage from the temp sensor. I Ohmed out the sensor and it is well within the specs when cold and at running temp of approx. 210 deg. I am getting 5.14 volts supplied to the temp sensor. Specs call for approx. 5 volts. Is the .14 enough to give the error? At this point, I'm stuck and could sure use some help as to what to try next. I considered the power train control module but all my other controls seem to be working well. Thanks it was actually the body control module (BCM). i replaced that and everything seems to be working fine. it's fairly easy to replace and you could do it yourself with little difficulty. all you have to do is plug it in. its under the steering wheel so you'll have to take off the peice underneath the steering wheel and there are 4 screws that hold the BCM in place. that's where it was on my '96, if it isn't there try underneath the glove compartment. should be the same for the '97 though. good luck and i hope it works for you. jwendell 10-29-2005, 01:28 PM i have a '96 JGC laredo, 5.2 V8, my temp. gauge reads the maximum all the time even though my engine isn't overheating, this causes my "check gauges" light to appear. this also causes my interior lights to blink noticeably when driving at night. i no longer have delay on my windsheild wipers. one time when i was driving the alarm starting going off, but that only happpend once. i have replaced the coolant/temp. sensor and that didn't fix the problem. after i replaced the c/t sensor, the "check engine" light appears but shuts off after a few miles. i've already tried turning my key on/off three time and leaving it on "on" on the 4th attempt to have my computer let me know what's wrong, but that didn't work??? also, my computer doesn't tell me that anything is wrong, i read in a thread that the computer should tell me a sensor is bad. is my computer going to hell?? does anyone have any idea to what may cause my guage to read faulty temps? thanks for the advice!! jw later that day.... i hooked up an OBD II to it and it read P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High Voltage". is this simply telling me what my gauge is telling me? any ideas on how to fix this error??? thanks... after some time and convincing the dealer to actually try even though they said it wasn't the problem. the body control module (BCM) fixed this problem. don't let the dealers try and tell you it is something else, they tested my BCM and said it was fine. i really had to persuade them to try a different BCM. this is something you can actually replace yourself, the BCM was under the steering wheel on my '96. jwendell 10-29-2005, 01:29 PM i have a '96 JGC laredo, 5.2 V8, my temp. gauge reads the maximum all the time even though my engine isn't overheating, this causes my "check gauges" light to appear. this also causes my interior lights to blink noticeably when driving at night. i no longer have delay on my windsheild wipers. one time when i was driving the alarm starting going off, but that only happpend once. i have replaced the coolant/temp. sensor and that didn't fix the problem. after i replaced the c/t sensor, the "check engine" light appears but shuts off after a few miles. i've already tried turning my key on/off three time and leaving it on "on" on the 4th attempt to have my computer let me know what's wrong, but that didn't work??? also, my computer doesn't tell me that anything is wrong, i read in a thread that the computer should tell me a sensor is bad. is my computer going to hell?? does anyone have any idea to what may cause my guage to read faulty temps? thanks for the advice!! jw later that day.... i hooked up an OBD II to it and it read P0118 "Engine Coolant Temperature (ECT) Sensor Circuit High Voltage". is this simply telling me what my gauge is telling me? any ideas on how to fix this error??? thanks... after some time and convincing the dealer to actually try even though they said it wasn't the problem. the body control module (BCM) fixed this problem. don't let the dealers try and tell you it is something else, they tested my BCM and said it was fine. i really had to persuade them to try a different BCM. this is something you can actually replace yourself, the BCM was under the steering wheel on my '96. thank you to everyone who participated in this discussion. jw jwendell 10-29-2005, 01:33 PM I have seen this before and it was actually the body computer.I still have no idea how because according to schematics,it is not supposed to have anything to do with the temp gauge.I had the luxury of an identical jeep to swap test parts from.The bcm was just a guess after trying the sensor,gauge and pcm. you were right, it took some convincing of the person working on it, but after i convinced them, they tried it and it worked. thank you for your help....jw xj31 10-30-2005, 10:52 PM you were right, it took some convincing of the person working on it, but after i convinced them, they tried it and it worked. thank you for your help....jw Thanks for the update.Glad you got it fixed. Glad I could help.I can understand why they did not want to try the bcm,it doesn't look like it is related,but I ran into this before(I'm a tech at a dealer,by the way) and after about a week of pulling out what little hair I have left,I finally started pulling parts off of my own personal vehicle and comparing voltage and resistance and the bcm was pretty much a last resort guess. Automotive Network, Inc., Copyright ©2012
