10-06-2005, 03:52 PM
first gen intake manifold
has anyone thought about or have taken the 90 degree bend out of thier intake manifold? you know the part right after where the throttle body bolts up.
10-06-2005, 06:55 PM
Tuning Neons since '97
Re: first gen intake manifold
I haven't personally thought about it, but I have seen it done. Some people cut off the bend and then weld the TB directly on. Pretty neat!
10-06-2005, 07:59 PM
so its doable? and do you think its worth the effort?
10-09-2005, 02:44 AM
anyone else?
10-09-2005, 09:06 PM
Re: Re: first gen intake manifold
If you have the means, then by all means. It does eliminate the 90° bend which is better for airflow.
10-10-2005, 04:16 PM
im doin it as i type, thanks
10-10-2005, 04:36 PM
I have seen adapters to put 1st gen TB on 2nd Gen Sohc manifold. I would think that would take less effort and you wouldn't have to break anything to do it.
10-10-2005, 05:18 PM
Are you gonna eliminate the EGR also?
Where and what if you have a DOHC intake manifold? Why would you downgrade?
10-10-2005, 05:19 PM
i have a first gen, and what am i gonig to break????? its a simple job
10-10-2005, 07:18 PM
I didn't see in the post if you have Sohc or Dohc.
Cutting your manifold up and welding it (dohc) or cement/gluing it (sohc) sounds like a risk of it not working when you are done (broken) to me.
10-10-2005, 07:50 PM
this has been done alot from what i heard without complications thats why i posted this thread so i could get feed back. i got good info from AF and others about doing this mod so im gonna do it and i will let you know. and post pics
10-11-2005, 01:07 PM
and post pics
That's what I will be waiting for...I want to see your fab work! Are you gonna port and polish the manifold while you have it off?
10-11-2005, 01:30 PM
yes im pnp myself but i want to get the welding done first, das you said you cut yours before what did you cut it with?
10-11-2005, 02:11 PM
No, I said I haven't thought about doing it, but that I have seen it done.
10-11-2005, 04:43 PM
ok it must have been someone else or another site
