Re: Clutch goes to the floor
You have a hydraulic (fluid assisted) clutch. As the friction material wears down on the clutch disc, more fluid is drawn into the system to make up for the change in relation between the disc, flywheel and the pressure plate, Just the same as how brake fluid level drops as pads wear down.
Honda's hydro's will work fine right up until air is drawn in, the you get the dead pedal like you have. If you aren't leaking, it's time to have the clutch disc lining inspected for wear. I think there is actually an inspection plug on the top of your tranny housing to look inside and see it.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
