Switch from conventional Oil to SynthHanibalTheCannibal 10-05-2005, 08:11 PM Well, I picked up some Mobil1 5W-30 fully synthetic oil and a Mobil1 206 Oil Filter for my next oil change. I got to thinking. Is there anything wrong with there being a little trace of the conventional oil left in the engine? I know it would be only a little bit (3oz maybe). Just wanted to make sure that it doesnt "foam" up or anything weird like that when mixed with synthetic. I have never used synthetic before. Also it says "15,000 mile", so how often do you really need to change this synthetic stuff?? :dunno: Thanks!! 2000CAYukon 10-05-2005, 08:17 PM I ran conventional oil until I felt the engine was broken in and then I switched to synthetic. There was no foaming or any problems with switching. I go about 7500 before changing synthetic. Part of that is that we don't put that many miles on the Yukon. I am sure others will share their preference for changer interval. //2000CAYukon HanibalTheCannibal 10-05-2005, 08:19 PM I ran conventional oil until I felt the engine was broken in and then I switched to synthetic. There was no foaming or any problems with switching. I go about 7500 before changing synthetic. Part of that is that we don't put that many miles on the Yukon. I am sure others will share their preference for changer interval. //2000CAYukon Broken in? So it was new when you started using synthetic?? I just bought this truck. Its a 2001 LS 5.3 with 40K miles. I am sure it has had regular oil all this time. I would think this engine is broke-in already :dunno:? jethro_3 10-05-2005, 08:31 PM Use it..... Go 5,000 on the first, use a test to see what is going on and then do what the test says on the second change.... Test and try.... 2000CAYukon 10-05-2005, 08:38 PM Broken in? So it was new when you started using synthetic?? I just bought this truck. Its a 2001 LS 5.3 with 40K miles. I am sure it has had regular oil all this time. I would think this engine is broke-in already :dunno:? I bought the Yukon new. I switched to synthetic when it had 10,000 miles on it. I have been running it with synthetic ever since. Now has 30,000. //2000CAYukon misfitt006 10-05-2005, 09:12 PM Use it..... Go 5,000 on the first, use a test to see what is going on and then do what the test says on the second change.... Test and try.... I just swiched to a synthetic blend on my last oil change a few days ago....what test are you talking about? What are the advantages of using a blend over full synthetic or conventional? ctesla 10-05-2005, 09:55 PM have ran the 15K extended mileage Mobil1 synthetic: @15K visc. breakdown was still nominal (professional oil analysis) and could have went another 3-5K, but I feel I got my money's worth. actually started getting better gas mileage after 7500miles. one thing people overlook when going with a 15K oil change: you still need to change the filter every 3-5K ! and would suggest using Wix (CarQuest/NAPA are Wix as well), or Mann, or Mahle, or an AC Delco Duraguard Gold. also, if you have ANY oil leaks, do NOT waste your money lubricating the driveway and highways, stick with a 20W50 conventional, and eventually take care of the leak. if you are an off-roader, or run the vehicle exceptionally hard, would suggest changing at 10-12K, rather than 15K. ...as to the original question, conventional and synthetic blend (hence the synth/blend oil). the original "foaming" issue was back in the '70s when many were still using NON-detergented oils. with VERY strict and stingent SAE rules and regs, and "energy-conserving" motor oils, you can mix oils/brands/weights, etc. now that I have said that, let me immediantely rekant: it is ALWAYS advisable to stick with same brand and weight (unless knowledgable in what you are experimenting with) and definitely have a "controlled" environment with your test vehicle as to what you are doing; however, one quart of Valvoline 10W30 in your four quarts of Quaker State 5W30 (or 20W50) will do no harm in the standard 3K-5K-7.5K oil change. also small amounts of conventional will not significantly dilute your synthetic. there are many sites on the web involving oil and filters: http://minimopar.knizefamily.net/oilfilterstudy.html http://www.bobistheoilguy.com/ http://home1.gte.net/vzep121w/ronspitstop/id27.html http://www.oilchangeguys.com/oilbbs/ (these are just a few) as long as regular maintenance is performed, longevity is to be expected. hope this helps, chris nrt racing Rollingbones 10-06-2005, 12:27 AM I 2005, GM was using an oil, part sythetic and part reglar oil. When I got my truck, I went straight to synthetic (Mobil 1 5/30) at about 3500 mils. No problems noted. jers99z 10-06-2005, 12:51 AM would it be advisabe to change over in a truck that has had conventional oil in it for say 6 years and 80k miles. Im trying to do anything to extend the life of my truck and try to improve gas mileage jethro_3 10-06-2005, 12:57 AM As stated earlier, change the filter as needed. Use a test like this: Lab Test (http://www.blackstone-labs.com/index.html) JCL82 10-06-2005, 05:50 AM If you have alot of miles on your truck don't switch synthetic oil.told ya later the story... White Lightening 10-06-2005, 06:14 AM Maybe I'm a bit confused. I've always believed the reason to use synthetics over conventional was higher heat handling and acid handling from hard use issues. If a truck doesn't have heat buildup problems - and doesn't accumulate acid because it is not worked heavily - why would synthetics alter m.p.g. or be desireable unless you drove alot of miles a year? I guess I figure if you have to change the oil filter every 3K to 5K - might as well change the oil at the same time. Especially the case - the newer Silverados with the oil monitor is monitoring the oil for usability as I read on one of the other threads (monitors not how clean - but lubricant capability). Input appreciated. White Lightening jethro_3 10-06-2005, 06:51 AM Why is it that people can find the most unrealistic reason to refute the capability of Synthetic Oil? :banghead: :banghead: :banghead: :screwy: :screwy: Don't break in new, :disappoin Don't use on old engines, :sly: Can't use farther than 3K miles, :eek: my dad did not use it so I can't, :nono: I know the book does not say 3K miles but I don't believe the book, :chair: I know the Corvette uses it from start up but that is different :owned: ... Hell, synthetic it is a governmental hoax???? :pimp: :twak: :devil: Evil, Evil, Stay Away, Evil, Evil!!!!!! :angryfire :newburn: I got it, I got it, the story about my heighbors cuzin's brother's lover said so..... Ok, rant over, pick a reason to not, someone will give you a good reason not to do it!!!!!!!!!! I'm sure you can find Oil in the origonal form like it was designed in say the early 1900's to use...... :thumbsup: jveik 10-06-2005, 10:59 AM why is everyone so nitpicky about the oil they use? get the right weight then it doesnt matter as long as you change it when needed. its all the same robjen 10-06-2005, 04:46 PM I had a 93 s10 blazer that I switched over to mobile 1 at 120k. And I didn't have any problems. Just make sure you change it after 2k for the first oil change. The syn will clean your insides. As for leakage. I had a slow leak on the botom of the motor and when I switched over, it actually quit leaking. I now use nothing but amsoil in my new truck. I put it in after about 7k miles. And I change it every 5k miles. Oil is cheap insurance. JCL82 10-06-2005, 08:12 PM Anyways ,here's the story, My mom car had like 130,000 miles on it.For some reason they switch to synth oil,she then started to have an oil leak because it clean off the dirt of the old seals. BlenderWizard 10-06-2005, 08:22 PM Anyways ,here's the story, My mom car had like 130,000 miles on it.For some reason they switch to synth oil,she then started to have an oil leak because it clean off the dirt of the old seals. When you clean out an older engine with heavy deposits, that can happen jethro_3 10-06-2005, 08:36 PM Anyways ,here's the story, My mom car had like 130,000 miles on it.For some reason they switch to synth oil,she then started to have an oil leak because it clean off the dirt of the old seals. So what you just said was the engine was not well kept BEFORE the switch to synthetic and the problem was the fact that a good choice was not used when it was needed?????? Maybe????? HanibalTheCannibal 10-06-2005, 09:30 PM Well, from what I can tell there are a lot more people for synthetic oils. I already bought 6qts and a filter. I am going to pick up my truck from the delaership tomorrow, and this weekend I will change oil. Is there any real results for better MPG from synthetic oil? Thats a possibility that I had not considered... JCL82 10-06-2005, 10:51 PM No, the oil was change every 3000-5000 miles,I just think the synth oil did it job by cleaning all that dirt,other crap off the seals and in the engine ,since it was 1997 camry with that many miles it started to ahve a oil leak,not a heavy one,but you could tell there was a leak,maybe a quarter size in the morning. Nothing major.But i thought i would give him a warning about it.I would say if you been using just regular oil and you pass 80,000 miles I would say stick with it unless you want a small oil leak.Since your under 40 that's not bad, i would give it a shot. I'm not against synth oil,heck I have it in my truck right now,amsoil and it works very well.I would just warn people about older engines and synth oils.. L98Driver 10-06-2005, 11:03 PM now when it comes to ur mom's car, like yeah it probably had a really hard/cracked up gasket/seal, i know that all mobil 1 products contain a perfect balance of seal conditioners/softeners, but still i mean that aint gonna stop it if ur seals sux, i have seen car's with that many miles switched to synth without probs but i assume they had healthy gaskets, tho i would NEVER wait that long to switch a car to synth, so I HAVE NO CLUE why they did that on ur mum's car yeah it's cool to switch, well idk the weights are up to u, i mean the oil companies say u can use just about anything u want, JUST BE SMART ABOUT IT, i don't give a f what the manual says, TO A CERTAIN EXTent, like u can play with it a bit, as long as u aint under warrenty, i wouldn't switch if u have leaks or unhealthy gaskets, cuz that can make more leaks, also mobil 1 and the GC/Green tint 0W-30 are great they are real PAO/Ester based synthetic oils, everything else suxxxxxxx and is petroleum based hydrocracked crap oil i mean they are superior to all other conventional oils, but they aren't as good as pao/ester based oils, royal purple, and redline oil are great, amsoil=Best, now the reason synthetics are superior to conventional oils is that they're molecules are of a uniform size so that everything is far better protected, they don't burn off as easily, and are well JUST WAY SUPERIOR, anyway, oh and that STUPID saying that u can't switch back to conventional well BULLSHIT, why the hell do u think it says COMPATIBLE WITH ALL CONVENTIONAL OILS on the back of the friggen bottle, so don't let anyone tell u that u can't, i mean that was maybe the case with early early early synthetics but no more, Also ur motor will be a heck of a lot cleaner with synthetics, conventional oils leave all kinds of crap behind, but like i said dont' waste ur money on the petroleum based synthetics, and the 3k oil change thing is crap to, i know a guy who used the GC in his bmw and the computer never called for an oil change until like 17,500 miles later, GM engineers say that the average life expectancy with most (conventional) oil is like just over 8,000 miles, amsoil offers oil change intervals of up to 25,000 and 35,000 miles if u use their filters changing them every 12,500 miles topping off the oil a tthat time, also royal purple and redlinoil i believe say that uc an use their oil for 12,000 miles, mobil 1 extended performance goes for like 15, i've done it on one filter with the mobil 1 EP, yeah 3k is a scam, i would run mobil clean 5,000 for 5k like it says with a quality filter if using conventional oil,oh yeah and when it comes to oil filters FRAMS SUCK!!!!!!!!!!!!!!!!!! jethro_3 10-07-2005, 02:34 AM Can We Get Another "Amen" for Brother L98Driver? Now Let's get Elvis Out Of The Building...... yakk 10-07-2005, 11:07 AM Maybe I'm a bit confused. I've always believed the reason to use synthetics over conventional was higher heat handling and acid handling from hard use issues. If a truck doesn't have heat buildup problems - and doesn't accumulate acid because it is not worked heavily - why would synthetics alter m.p.g. or be desireable unless you drove alot of miles a year? I guess I figure if you have to change the oil filter every 3K to 5K - might as well change the oil at the same time. Especially the case - the newer Silverados with the oil monitor is monitoring the oil for usability as I read on one of the other threads (monitors not how clean - but lubricant capability). Input appreciated. White Lightening For us folks in the northern climates, another benefit is easier cold weather starts. With synth, you don't have that deep frozen sludge-like consistency on sub-zero mornings. Automotive Network, Inc., Copyright ©2012
