92 Lumina Z34 won't start has spark
SavageAddict
10-04-2005, 06:14 PM
Hello,
I was wondering if anyone could point me in the right direction. This is a friends car she drove it over the other day and now it's won't start.
It cranks just fine. I checked for spark and I do get a spark. I can hear the fuel pump run when I switch the ignition to run.
I have read that it's possible that the crank position sensor may cause this. However I can't seem to locate it.
Any ideas???
jeffcoslacker
10-04-2005, 09:02 PM
If the crank sensor wasn't working, you'd have no spark. Offhand I'd guess she popped a timing belt. How many miles on it?
jeffcoslacker
10-04-2005, 09:03 PM
Pull a plug out and see if the compression seems weak.
SavageAddict
10-04-2005, 09:47 PM
It has 125,000 miles on it.
I still think it might be fuel related... She just bought this car and was showing me everything. It stalled while I was sitting in the driver seat and would not restart.
I have noticed that if it sits for a period of time and you try to crank it it sounds like it wants to start. I'm thinking that the injectors are leaking down after sitting.
I didn't change the fuel filter, maybe it's clogged?
jeffcoslacker
10-05-2005, 08:09 AM
It'd be worth trying. See if Autozone can loan you a fuel pressure gauge, test the pressure at the rail. Try seeing if it fires on some ether, that'd prove/disprove your suspicion.
commander5018
10-24-2005, 05:56 AM
The car has the anti-theft chip under the dash at your right knee. While turning the key giggle the chip and I'll bet she will start.
