Dead window motor
Voxxx
05-17-2002, 01:05 AM
The power window motor went out in my car while the window was down, I can't figure out how to get it back up, can anyone help me?
:licker:
SPLThunder
06-16-2002, 11:54 PM
:badass: My friend recently had this problem. First thing to try is just bang all around on the inside of the door panel. This might loosen the motor if it has gotten corroded. If that doesnt work you should take the door panel off and look at the motor. This way you will be able to see if it is corroded. If you can uncorroded it in any way do so. If not i would go and buy a new motor and install it myself. It shouldnt be to hard.
tbirdmaninva
07-18-2002, 09:54 AM
try to pull the window up while someone hits the window switch.
TerminalVelocity
07-20-2002, 07:55 AM
worked for me before
MercCougarXR7
08-13-2002, 11:19 AM
Could also be JUST the switch on the door!
They're cheap, and fixed my window - it also wouldn't go up after it went down one night - pissed me off. So, I tried a switch first, and what do you know - it solved the problem.
Until next time - this is the 2nd time I've replaced that switch in 3 years.
cougargurl93
06-03-2003, 05:16 PM
my driver side window went out and wont roll down. wondering if anyone else had this prob. with the 93 cougar b/c there have been a few recalls on parts for this model. dont want to buy a new motor and it only be the switch. know what i mean
Mr1der
07-18-2003, 12:54 AM
does the motor sound like it's running when you push the switch?
ford and some the other makers decided to use crappy plastic gears in the motor that are prone to breaking, I've had two go out on my bird.
but if it sounds to be running, it probably broke the gears
Burnit_420
08-25-2003, 12:57 AM
I have a 86 T-Bird and I just recently had to replace both motors. For some reason both went out at exactly the same time, and were both stuck about a 1/4 of the way up. They are pretty easy to replace, but 65 bucks each is hard for me to pay, so I hope they last a while
