1990 3.1 No Injector Pulse - Intermittentwoodautogroup 10-04-2005, 12:07 PM Hello I am working on a 3.1 that has an intermittent no start problem. When the car does not start there is no injector pulse. There is always spark and good fuel pressure. I have tried several other ECUs that I have lying around and the same problem exisits. Could this be an ignition module issue even though there is always spark? Please advise. meuhus 10-05-2005, 09:19 AM Hello I am working on a 3.1 that has an intermittent no start problem. When the car does not start there is no injector pulse. There is always spark and good fuel pressure. I have tried several other ECUs that I have lying around and the same problem exisits. Could this be an ignition module issue even though there is always spark? Please advise. sounds more like a wiring issue the wires from ecm(u) to the injectors or a ground or short bad wires are all the injectors losing pulse or just one or two that is my guess woodautogroup 10-05-2005, 10:44 AM That is what I am thinking too but I have tried everything I can think of. I replaced the injector harness because it seemed like if I moved it around it would create a miss. That fixed the miss but didn't help the int. no start. I powered the injectors directly and ran new wires right from the ECM to the injector harness with the same on again off again no start issue. I have tried the ignition module with no help either. I checked the grounds and power to the ECM and they all seem good. Any more ideas? meuhus 10-05-2005, 10:55 AM That is what I am thinking too but I have tried everything I can think of. I replaced the injector harness because it seemed like if I moved it around it would create a miss. That fixed the miss but didn't help the int. no start. I powered the injectors directly and ran new wires right from the ECM to the injector harness with the same on again off again no start issue. I have tried the ignition module with no help either. I checked the grounds and power to the ECM and they all seem good. Any more ideas? my lumina would do a similar not start thing the car would die and not start back up it would also drain battery after i fried the first battery put in a new one was fine for a while but then went to work one day and it turned over kind of slow again didn't think much about it till i got to my parents house had my dad come out and listen then the car would not turn over thinking it could have been the alternator at first but then realized that i had lights and 12 volt at the battery then figured it was the starter i pulled it out had it rebuilt worked fine ever since if you have spark all the time its not ign mod but it may have some thing to do with the crank sensor it is in the back of the block near bottom middle it a pain have to rotate the motor to get to it but when i replaced mine (thinking this was one of my problems only $20) the outer plastic was cracked this controls the timing and may tell the computer when to turn on injectors too just a guess dennisinmo 10-05-2005, 11:42 AM Sounds like the crank sensor. If you have checked everything else, you might want to replace the crank sensor. Be very, very careful when you do. Mine was brittle and broke off when I tried to remove it. Half was in my hand and the other half was in the oil pan. Finally had to remove oil pan to retrieve it. BUMMER. woodautogroup 10-05-2005, 12:35 PM Sounds like the crank sensor. If you have checked everything else, you might want to replace the crank sensor. Be very, very careful when you do. Mine was brittle and broke off when I tried to remove it. Half was in my hand and the other half was in the oil pan. Finally had to remove oil pan to retrieve it. BUMMER. Thank you. I just tried the crank sensor and it was cracked but the new one didn't help. Pretty frustrated at this point. To answer a question from above there is no pulse at any of the injectors. The car seems to always crank very stong. The starter appears to be recently replaced. meuhus 10-05-2005, 01:22 PM Thank you. I just tried the crank sensor and it was cracked but the new one didn't help. Pretty frustrated at this point. To answer a question from above there is no pulse at any of the injectors. The car seems to always crank very stong. The starter appears to be recently replaced. is the service engine light on or are you getting any codes woodautogroup 10-05-2005, 02:00 PM No Engine light. The only codes that I have were 32 and 33 (I think they were the numbers) Too high and too low Map Sensor readings. I think that was from when I unhooked the vac line while it was running to see if there was vac there. I have swapped the MAP out with another from the shelf with no effect. Baffeled...... Thank you. I just tried the crank sensor and it was cracked but the new one didn't help. Pretty frustrated at this point. To answer a question from above there is no pulse at any of the injectors. The car seems to always crank very stong. The starter appears to be recently replaced. maxwedge 10-05-2005, 04:34 PM Get a scanner on it and see if you get cranking rpms when it won't start. woodautogroup 10-06-2005, 07:01 AM Yes, there is always a RPM signal when it runs and when it cranks and doesn't start. Usually around 250 to 300 when cranking w/ no start. Get a scanner on it and see if you get cranking rpms when it won't start. meuhus 10-06-2005, 07:58 AM Yes, there is always a RPM signal when it runs and when it cranks and doesn't start. Usually around 250 to 300 when cranking w/ no start. well i'm stumped sounds like something is telling the computer to turn off the injectors if you changed the wire harness and switched ecms that is a tough one could the computer be getting a bad reading from the tps telling it that its flooded and shutting of the injectors or something like that maybe maxwedge 10-06-2005, 01:04 PM When this happens try tap testing the pcm, use a screw driver handle and give it a coupla moderate taps on the case, see what happens. also watch for bad connections at the ICM. richtazz 10-06-2005, 01:08 PM check your ECM. IF the factory number on it is 1227727, you need an ECM. These units have a very high failure rate, and combine that with being mounted under the hood exposed to the elements on your car, I would bet that is where you problem lies. meuhus 10-06-2005, 04:00 PM check your ECM. IF the factory number on it is 1227727, you need an ECM. These units have a very high failure rate, and combine that with being mounted under the hood exposed to the elements on your car, I would bet that is where you problem lies. he changed out yhe ecm a couple of time i think he said any way that is what it sounds like to me too richtazz 10-06-2005, 04:29 PM try testing the harness between the crank sensor and ignition module for continuity, maybe you have a broken wire. woodautogroup 10-06-2005, 05:48 PM I changed the ECM with two others with the exact same results. I thought about the carnk sensor wires too, but I wouldn't have spark all the time if they were bad, would I? Does anyone know exactly what inputs (and paths, ie through the Ing. Mod. then to the computer, or right to the computer, etc) the computer uses to determine the fuel timing/duration? I assume that the Crank sensor is number 1. MAP #2 and from there the IAT sensor and TPS sensor trim things out. But typically a car will run w/o the IAT and TPS, etc sensors even plugged in. I tried unplugging most of the typical sensors one at a time and all together and other combos with no help. The car only tried to start once today and has been a crank and no start the other dozen random times I tried today. :( he changed out yhe ecm a couple of time i think he said any way that is what it sounds like to me too Automotive Network, Inc., Copyright ©2012
