Heater problem?
BenBB
10-04-2005, 10:39 AM
I have a '96 JGC and the heat does not work. I have flushed out the cooling system and the heater core and nothing leaks. When i drive for a while and turn the heat on, it just pumps out cool air. Does anyone know what it could be?
dksob81
10-04-2005, 10:59 AM
You did use coolant (antifreeze), right? Some people put straight water in as a cheap substitute for coolant, which sometimes is fine for summer but for winter it willl not cool distribute the heat to the heater core like coolant.
I had to flush/reverse my heater core last winter due to a no heat situation (you might want to look it up on the forum, I posted a thread with some handy info on how to do it).
Other then that the problem would lie in the control assembly.
BenBB
10-04-2005, 02:32 PM
Yea i used antifreeze, but i will look at your forum. thanks
