Originally Posted by purice
Can you tell me what is that and how can be fixed please? Excuse my ignorance!
That would be your catalytic converter. If it is clogged you would just have a shop replace it with a good one or buy your own and have a shop weld it into place. That being said, I doubt that is your problem.
Originally Posted by neon_rt
Sounds like the Cat could be plugged.
I doubt it is the cat. They rarely go out on a neon and you would be getting a Code 77 for the cat converter failure. The spark plugs you bought, K&N, are not platinum plugs are they? You could have a failing or stuck EGR valve. You say your check engine light was blinking, did you read your codes and see if there are any?
