Check Engine Light
Google
Web AF
renderman8
10-02-2005, 08:51 AM
Hello I have a 2001 Qx4 3.5 Liter engine with only 38k miles on it. Surprisingly the "check engine" light came on yesterday. I was wondering if there is simpler way of reading the code without a scanner? Or do I have to go the dealer or an auto shop. Could be a Oxygen sensor. Is there any danger or harming the engine if I wait a few months before checking it? I heard of people driving for months and doing nothing.
I was wondering if any body here had any experience in dealing with the engine codes. Any chance this "check engine" service is covered by the 6 year engine warranty?
I had a very bad experience 2 weeks ago with my 98 Nissan maxima which the "check engine" light came on. It was an Oxygen and a knock sensor. I took it to my mechanic that I have use for years. I was shock and angry when he charge me $680 to scan and replace the 2 sensors! I was stupid to allow the service :banghead: But what done is done. I certainly would go back to him again. :disappoin
Any help or tips would be greatly appreciated, thanks.
lewisnc100
10-03-2005, 08:10 AM
2000 and earlier had a screw on the computer that allowed you to retrieve the codes without a code reader, 2001 and later don't have that anymore. You really need to find out what the code is before anyone can tell you anything about it, try Autozone or a local auto parts store that will read it for free.
renderman8
10-03-2005, 09:30 PM
Oh I didn't know that Autozone will do a free scan check. Hopefully the autozone here in NY is the same like other states? I do have an Autozone near by. Thank u for the info.
Skyman619
02-11-2006, 06:26 AM
hello, i suggest you to take (negivate) off the battery, then wait 30 to 50 sec. then hook backup the battery. it would be clear light engine. dealer is really shiz and bullshiz.
circeseye
02-11-2006, 05:28 PM
also with a check engine light comes on and you dont see any difference in the way it runs check these things
make sure your gas cap is on tight
check your fluids. (if you water is low it will send up to 3 codes po115 po420 po125)
i
i know of the water one cause it happend to me yesterday :shakehead
ihatemycar45
02-11-2006, 06:10 PM
Hi can someone help me I hade a aftermarket cat put in my 99 camaro v6 after I had that done my Check Engine Light came on the code I got was a PO420 and then a Po420 pending code. My Check engine light was not on untill they put the cat on. Can someone tell me what I can do to fix it
Thank you
circeseye
02-12-2006, 02:51 AM
try clearing the computor first and see if it comes back if it does take it back to the shop that put it on they forgot something or damaged something (like the sensor)
oh and do you know this is a nissan (pathfinder) forum thread :iceslolan
Andrewh
02-13-2006, 03:52 PM
If this is the first time you have seen it, then I think I have bad news. The rear o2 sensors on the pathfinder had some problem, where the computer had to be reprogramed, and the sensors replaced. It is a tsb not a recall item.
Google
Web AF
