intermittent wipers
wayne crouse
09-30-2005, 11:12 PM
intermittent wipers , will not intermit turn switch on they say on all the time, where is the module or relay for the intermittent wipers located?
87 honda civic
lxndr
09-30-2005, 11:34 PM
You don't have a problem.
The wipers only have slow, fast and ludicrous speed.
Push down on the wiper switch arm to make the wipers swipe once.
lxndr
10-01-2005, 08:35 PM
Whoops! I was wrong...
There is an intermittnet setting on the switch. If yours isn't working it's either a problem with the switch or the wiper motor. You can check both with a multi/volt meter. A few years ago my wipers stopped working completely and it turned out that the wiper motor had fried.
avistar
10-13-2005, 07:09 PM
Look just above the fuse box under the bottom right side of dash. There are two large square boxy things that can be pulled out. One is the flaher unit and the other is the intermittant relay. Replace if necessary or find one in the junk yard and swap. JS
lxndr
10-15-2005, 03:40 AM
Good to know.
