how to change the engine mount inserttvuong 09-30-2005, 07:37 PM Hi, I need to change the front and back engine mount insert for my 99 ford contour dual headcam. Can someone help me the procedure of how doing it. i understand that i need to jack my engine to the point that i can remove the bolt easily. Should I remove the whole mount assembly (un-bolted 3 bolts to the engine and 2 nuts under the crossbar member) than work on the insert when the whole unit removed from the car. Or you have any tip to make it easier. Thansk beyondloadedSE 10-01-2005, 01:54 AM are you putting poly inserts into the front roll resistor or are you changing the roll resistor all together?? If your just putting in poly inserts, then I dont think the roll resistor needs to be removed. I cant remember for sure. I replaced mine with SVT ones, so I had to remove them anyways. I think the inserts can be put in before or after the roll resistor is installed. I just jacked up my car and put some jacks on either side and then got the jack and jacked up the engine on the bottom of the oil pan with a piece of wood to distribute the load. Mind you it wasnt much pressure, since the rear roll resistor and top 2 motor mounts were still intact. Automotive Network, Inc., Copyright ©2012
