1998 jeep grand cherokee overheating. please helpTommygunlee 09-30-2005, 06:39 PM my jeep grand cherokee gets hot enough in traffic to cause the speed sensor to go bad. It gets about 250 degrees but seems to do ok when i'm on open highway. I have replaced the radiator, thermostat, fan, fan clutch, and had the system flushed. If someone has a solution please help. thanks dksob81 09-30-2005, 08:35 PM does it take long to warm up? Sounds like you thermostat is stuck open, this usually causes the jeep to take longer to get up to temp. Try replacing your T-Stat or even switching to a cooler T-Stat (I currently run a 160 degree t-stat, stock is 195 degree, in my 94 5.2L). GregA 10-01-2005, 01:12 AM my jeep grand cherokee gets hot enough in traffic to cause the speed sensor to go bad. It gets about 250 degrees but seems to do ok when i'm on open highway. I have replaced the radiator, thermostat, fan, fan clutch, and had the system flushed. If someone has a solution please help. thanks You didn't mention changing the Water Pump. That may need to be replaced since it is the main component to circulate coolant. It may work "OK" at highway speeds, but have low flow at idle or in traffic. Take Care, Tommygunlee 10-01-2005, 06:55 PM I will put a new t-stat in it and replace the water pump, and if that don't fix it then i'll ride her till she quits. thanks for the help fellas Automotive Network, Inc., Copyright ©2012
