90 318 5.2 stallscrubar 09-30-2005, 03:28 PM i have a 1990 d150 that just started stalling ,160,000 km does it when its hot or cold. idling in park or driving ..its random may not do it for a day or two...then may do it 3 times in 4 blocks ? truck is all stock and been a dream thus far... stalls just like someone turned the key off... hoping for some help ...as im lost on this one doggfather69 10-07-2005, 07:33 AM I had the same problem in mine. I started with the vaccume hoses. I found two that were cracked and changed them. I also changed the pvc and the fuel filter and the problem was solved. Hope that helps. doggfather69 10-07-2005, 07:35 AM Also check the terminals at the battery for corrossion and I would take them off and clean them anyway. Let me know compliment29 10-07-2005, 02:04 PM water in gas buy some gas line anti freeze or methyl hydrate it will remove the moisture and switch gas stations fredjacksonsan 10-11-2005, 02:59 PM Any update? Did those items fix the problem? fanworks 10-15-2005, 09:56 PM Gonna say dead fuel filter. Its exhibiting problems we had with a Chevy Suburban when the filter died. I'd also do the water check bit. I have the same year,make truck, and its still running the stock filter, gonna change mine out in the not too distant future here. Yours is the 5.2 with the TBI on the top, correct? Just want to make sure, as that's the configuration on mine. 89ltd 10-19-2005, 05:51 AM I would change the pickup coil in the distributor, same thing happened to my 88 and my Dad's 89. I replaced lots parts for nothing because the pickup coil did not produce a code in the computer. Finally it came up with "no distributor reference signal" itsdave4321 11-20-2005, 07:35 PM check the map and oxgen sensor netmech 11-21-2005, 01:08 AM You probably have a vaccum leak in the intake manifold.. probably the plenum gasket.. $750 for the dealer to fix it.. $50 do it yourself.. but it takes a good weekend. Automotive Network, Inc., Copyright ©2012
