Rotten Egg Smell
Duley3
09-30-2005, 07:33 AM
I have a very bad smell when I step on the gas. It smells just like rotten eggs. I was told that I need to greese the muffler bearings. Because they were low on greese the bearsings were getting hot and that was the smell.
Could this be the problem? and if so were would I find the bearings?
1998 2.2 with 128??? miles
Young Chuck D
09-30-2005, 08:10 AM
rotten eggs smell = sulfur...... [i'm an amature but] check ur battery knob thingies...
jakegday
09-30-2005, 08:54 AM
it could be your catylic converter,
cdru
Could this be the problem? and if so were would I find the bearings?Wow. Um. Not sure if you are serious or not, but assuming you are, your car doesn't have muffler bearings. They were playing with you.
Rotten egg smells is usually either very rich fuel mixture (hows your MPG lately?) or a plugged catalytic converter.
Duley3
09-30-2005, 09:24 AM
:rofl: :rofl: :rofl: :evillol: :evillol: :evillol: :screwy: :screwy:
I just wanted to see what you people would say...
I know that it is my catalytic converter . What I don't know is this...??? Is there anyway that I can fix the problem with it being clogged.
Could I take it off and cram a broom stick or something thou it?
Or would this hurt the preformance of the car?
Or should I just replace it?
Thanks
Dave
-Jayson-
09-30-2005, 10:08 AM
Thanks
Dave
LMAO no you werent, dont try and save face now. U just asked if you could clean your cat with a broom stick. Only solution is a new converter.
cdru
09-30-2005, 11:21 AM
Could I take it off and cram a broom stick or something thou it?Yeah sure. That might do it. :shakehead
The inside of the cat is like a honeycomb with fairly small passageways. These can get plugged up over time if your car is not well maintained, essentially cutting off the flow of exhaust through the converter. As Jayson said there is no way to really clean it other then replacing it. Besides, even if there was, you'd have to cut the old converter out and reinstall it. Is it really worth all that effort and not have it fix your problem when for $75 you could just buy a new one?
bh04
09-30-2005, 12:51 PM
Mine had the same problem about two months ago. I took a hammer and beat the crap out of my cat. Which don't ever do. But I went and had to buy a new cat. I got the magnaflow from gravana tuning. It's $75, but sounds really nice.
http://www.gravanatuning.com/applications/2000_Chevrolet_Cavalier_Coupe_2.2.aspx/2/193/_Catalytic_Converters_Magnaflow_Carsound_OBD_II_St ainless_Hi_Flow_Cat
KustmAce
09-30-2005, 12:54 PM
^^Same one Ive got. Fixed that nasty ass smell too.
ImSoYesterday
09-30-2005, 01:12 PM
I would have also suggested teh clutch going. But, you cannot save yourself when you said 'muffler bearings' and how would a cat do ANYTHING if it was a straight through? But go nuts. If you are getting a new cat just snag one off of E-bay, cheap and they work.
Duley3
09-30-2005, 01:50 PM
Sure is easy to get you people going.. :evillol:
4dr92cavi4cyl
09-30-2005, 02:15 PM
What? Muffler's don't have bearings? Damn, how many people have I told to grease their muffler bearings... LMAO!
Yes, it's easy to get us going, almost TOO easy!
Yes, I know muffler's don't have bearings, that was just hilarious.
jakegday
09-30-2005, 05:24 PM
he makes a good point......
KustmAce
10-01-2005, 04:20 AM
'nuff said
Be sure to check your headlight fluid while your at it, it could be low. :evillol:
Duley3
10-01-2005, 08:37 AM
I was more worried about the valve stem lube.... Should I change it too?
So I need
New muffler bearings
Heallight fuild needs checked
Change Valve stem lube.
And check the oil pressure in the tires.
:screwy: :banghead: :rofl:
ImSoYesterday
10-01-2005, 11:26 AM
Oh man, don't overlook the most simplest of simples! (Which every mechanic always overlooks) Check the coolant to your tires! What do you think prevents them from getting too hot and melting?
I am unfamiliar with the term valve stem, is it where one mounts a breather filter? Because if so, my cousin's has lube on it, it was really big and the filter wouldnt slide on easily on his 4g63.
bh04
10-01-2005, 12:31 PM
Ok this might be going a little bit too far on things you should check. But some people have been having problems with the gas for there power windows and locks. Try and get that filled to see if the windows will go up faster and down faster and the locks locking faster.
4dr92cavi4cyl
10-01-2005, 03:59 PM
Wow, this thread is amazing, I never thought about these things. Don't forget to oil your gas pedal so it doesn't get stuck when you floor it. I hope nobody takes this thread seriously, imagine some people putting oil in their tires, sticking grease in their muffler, and adding coolant to their headlights. LMAO!
madkillshire
10-01-2005, 08:40 PM
Does the Engine have a misfire? The smell of rotten eggs is usually cause by a rich fuel mixure or a misfire. You need to make sure the engine i running properly before replacing the cat.
Project_Cav
10-02-2005, 03:53 AM
dood its the cat..if his car wasnt running properly or using too much gas he would have started off by talking about the problems hes experiencing with performance...speaking of which..i gotta replace mine cuz im getting that same gross ass smell
bh04
10-02-2005, 04:24 AM
When I had to replace my cat, my car wouldn't shift outta 1st gear, so I couldn't go no where. It was clogged, and ya smelt horribly awful. I think that it's all summed up that, you need a new cat. Maybe the one you have now is shedding too much or poops all over the place.
Sorry, I got out of hand. I just thought i'd put a little humor into my post. Def go wtih a non OEM. SOunds way better and flows more!
