00 Camry Backup LightsNicksCar 09-28-2005, 10:14 PM BOTH backup lights on my 2000 Camry (Auto,4 Cyl, LE) do not turn on when the car is placed in the Reverse gear. I've checked the fuse and it was fine (located in the passenger compartment, on the left side of the steering wheel, behind the coin holder). I've changed both bulbs for the backup lights, but that didn't fix the problem either. My next guess is the backup light switch, which I found out is located behind the engine block, close to where engine/transmission are mated. Anyone out there that has experienced a similar problem? Could the problem be something other than the backup light switch? What's the best way to change the backup light switch? Where to buy parts at a reasonable price? Tools necessary for the fix? thanks ! Daniel M. Dreifus 10-01-2005, 03:07 PM see if you have a wiring harness running along a trunk hinge that flexes frequently Joe W 10-03-2005, 08:21 AM The Haynes manual has a test for the reverse/neutral safety switch that might help. The book is only about $15-20. howru 10-03-2005, 01:35 PM hey, I just fixed this problem on my car beatifully. It's not caused by defective switch if you don't get a code. check the wires in your trunk. The red-black should be for your back-up light. Carefully track the wiring as deep as possible. Mine is cut somewhere almost out of the truck, just allowing me to see it. NicksCar 10-07-2005, 11:55 AM Thanks for your response, after reading your message I checked the wires in the trunk of the car and sure enough, they had snapped. tsicamry 10-11-2005, 12:46 PM starting in the morning icon went on showing rear lights(Under thermal sensor on 00 Camry) what could it mean? Mike Gerber 10-12-2005, 01:57 AM starting in the morning icon went on showing rear lights(Under thermal sensor on 00 Camry) what could it mean? It usually means you have a bulb burned out in the rear. Check all the rear lights including the high mounted brake light and also any double filament bulbs in the rear. Mike Automotive Network, Inc., Copyright ©2012
