98 Camry- Gear shifting
chandr
09-28-2005, 02:08 PM
Hi,
I had 98 Camry XLE (Auto Transmission) and purchased this car one year back. Currently the mileage is 57,260 miles.
I cleaned my transmiison using Auto-RX and changed it after 2000 miles
using transmission fluid flush. whenever i accelerate and then ease up on the gas pedal, the car kicks a bit when the engine temparature is cold. I didn't find this symptom when engine temparature reached the required level
I wants to know what are the causes for this symptom and how to rectify this problem.
Thank You in advance
Chand
Daniel M. Dreifus
09-28-2005, 08:13 PM
to help the car reach normal operating temperature more quickly, the coolant temperature sensor will not let the ECM computer shift the transmission into overdrive until a certain minimum temperature is reached - could just be that.
Brian R.
09-29-2005, 04:38 AM
Also, the transmission shifts are stiff and at unpredictable and abnormal rpms when the engine temperature is cold.
