Occasional problems with hot startsbeckeja 09-28-2005, 09:01 AM My 1997 Camry LE (91,000) will occasionally have problems starting after the engine is hot. For example, after driving on the highway for 30+ minutes and then trying to restart the car, it generally takes 3 attempts before the car will eventually start. It turns over, but does not start. I have never had this problem on a cold start, it always fires up. It has new spark plugs and the battery seems strong. Thanks for any advice. Toysrme 09-28-2005, 01:39 PM Clean the IAC valve. burchard 10-04-2005, 02:07 PM Clean the IAC valve. The engine coolant temp sensor might be tarting to give you some trouble. There are several post hee that deal with that issue. beckeja 10-17-2005, 10:15 AM I finally got around to cleaning the IAC valve. So far, I have not had any further problems, but since this happens infrequently, I will continue to monitor. I appreciate the information. Thanks Automotive Network, Inc., Copyright ©2012
