Help, tips, or suggestions...whateverSean Price 05-15-2002, 10:22 AM hey all I finally got my wheels mounted and balanced and put on my car. Now heres my problem, everything is fine except for the left front tire. Every other day I gotta go put air into it because every other morning I find that its flat? what do you all think is wrong? what is the deal? what should I do go to where they put them on? or call the place where I bought the tires? thanks for all peace JayFidizzy 05-15-2002, 10:28 AM I'd go to where they put them on first. It sounds like you have a slow leak due to either a tear in the tire...maybe a screw or the tire isn't mounted properly. If its a tire defect then goto where you bought the tires....they still should be guaranteed SleeperTeg 05-15-2002, 11:23 AM or a leaky valve stem. when i got my new wheels/tires, i had 2 of them that developed slow leaks. fill the tire up and then spray some water on/around the valve stem, then wiggle it a bit. will see bubbles if it is coming from the valve stem. good luck JayFidizzy 05-15-2002, 12:03 PM Originally posted by SleeperTeg or a leaky valve stem. when i got my new wheels/tires, i had 2 of them that developed slow leaks. fill the tire up and then spray some water on/around the valve stem, then wiggle it a bit. will see bubbles if it is coming from the valve stem. good luck forgot about that one....good call...i'd bet its probably that over anything else. CivicSiRacer 05-15-2002, 01:15 PM Originally posted by Sean Price hey all I finally got my wheels mounted and balanced and put on my car. Now heres my problem, everything is fine except for the left front tire. Every other day I gotta go put air into it because every other morning I find that its flat? what do you all think is wrong? what is the deal? what should I do go to where they put them on? or call the place where I bought the tires? thanks for all peace What my email reply wasn't good enough? Automotive Network, Inc., Copyright ©2012
