Can Rodeo brake pedal distance be changed?Joihan777 09-27-2005, 09:10 PM Hello fellow Isuzu owners, Have a question about the brake pedal in a Rodeo/ Sport: Can the pedal distance be changed to accomodate longer legs? Recently I ran a power cable under the driver side and I noticed that there are opposing screw housings on front & rear of brake pedal arm. Does this mean the brake pedal arm can be moved back an inch or two? Any response would be appreciated, thanks. johann **Wish I could show a picture** Cat Fuzz 09-28-2005, 12:37 AM Those screws are pedal stops. Its best not to mess with them. The brake pedal position can't really be changed, unless you maybe wanted to remove it and have it cut and rewelded. Then you run the risk of changing the pedal geometry and causing unforseen problems. It would be best to just live with what you have. Automotive Network, Inc., Copyright ©2012
