turbo help
Google
Web AF
amelio1
09-27-2005, 07:38 PM
i currently have a 98 neon and im looking into getting a hahn racecraft stage 1 turbo kit and i was woundering what other modifications i should do along with it. i need to know everything about what i need to do. thanks!!!!
das2123
09-29-2005, 03:11 PM
i currently have a 98 neon and im looking into getting a hahn racecraft stage 1 turbo kit and i was wondering what other modifications i should do along with it. i need to know everything about what i need to do. thanks!!!!With a stage I kit, you can keep your stock internals, as you will only see boost from 5-7psi. If I were you, I would spend the extra $400 and go with the stage II kit and get the intercooler. Added HP and it will keep your turbo from blowing up. As far as other modifications to go along with it, this is what I would do:
* 3" Modern Performance Exhaust (http://www.modernperformance.com/dcx/mpx3inchturbo.shtml) - it bolts right up th the Hahn turbo
* MPx UDP (http://www.modernperformance.com/dcx/mpx9599p.shtml)
* MPx TB (http://www.modernperformance.com/dcx/mpx_tb.shtml)
*You should also look into some prothane or solid motor mounts and a solid bobble strut. This will help with the incredible wheel hop you will encounter.
That should get you started. After that I would look into Crower rods and JE pistons to help reinforce your engine.
Google
Web AF
