Quirky Electircal issues
Muddskipper
09-27-2005, 10:48 AM
I'v got 170,000 on this 2wd SUV and love it.....
2 Problems on my 99 Rodeo that you guys might be able to help with...
First- my Alarm will no longer allow me to unlock all doors, I hit it the first time to unlock the drivers door ( no problem ) but the the second push will no longer unlock the rest of the doors.....
Any suggestions ????
Second- My little clock no longer lights up, so at night I cant check the time.... and yes I do own a watch...its just bugging me...
What do you guys think???
Cat Fuzz
09-28-2005, 12:22 AM
You might have a bad relay in your alarm system.
You probably need to replace the bulb that illuminates the clock.
hroark7
09-28-2005, 06:11 PM
If that's the same clock as in the '01, I was having electrical issues as well - turns out that some bad soldering (from whomever manufactured the clock) was shorting out my illumination controller by sending the dimmer switch line to ground at the clock. The best way to remedy this is to either get a new clock and install it, or leave it as is (burned out). Also, if the clock is the same as the 01, it doesn't have a changeable bulb
The alarm seems like a different problem. If it was a blown relay,it probably wouldn't work at all. Does your power door lock relay/control module work correctly when you try it manually? That might be a good place to start.
rodeo02
09-28-2005, 09:26 PM
The clock issue is super common on the 1998+. You are lucky yours lasted that long! You have to either pull the dash bezel & replace the whole clock, or gut the clock & solder in a new lamp. I'd leave it! Not sure about the unlocking thing. Will the remote lock ALL the doors, but only unlock the drivers?
G/luck
Joel
Cat Fuzz
09-29-2005, 12:00 AM
Taking things apart is fun! Especially if there is soldering involved. I like to solder.
Muddskipper
09-29-2005, 10:38 AM
Thanks for the replys
As for the Alarm, I can still lock all the doors with 1 push of the remote and my controlls inside work fine.
Could it be a blown fuse?
or
where should I start?
also- it sounds like the clock will stay without a light.
php
10-05-2005, 03:35 PM
Check out the thread started by mckpaul on "Intermittent wiper problem" there is mention of a remote entry box in it. May help.......may not.
mapua82
10-05-2005, 03:48 PM
I got the same problem at ~40,000 mi, i just gave it a little BANG with my palm and it works.
