1997 JGC - can't disarm alarm, won't start
omusogeorge
09-26-2005, 10:40 PM
I can't seem to disarm the car alarm and the vehicle won't start. Before when this happened, I would just stick the key in the drivers side door and turn it. Now, that doesn't work and nothing I do can seem to disarm it. How do you turn off the alarm so that you can start the vehicle????
Moose
ALICIAEDGAR
09-29-2005, 10:47 AM
Moose
HAVE YOU GOTTEN ANY ANSWERS FROM ANYONE. I'M NEW AT THIS. I HAVE THE SAME PROBLEM WITH MINE. PLEASE HELP.....
omusogeorge
09-29-2005, 09:25 PM
No I haven't gotten any replies. At this point, I will be taking the vehicle to a dealer/service center this weekend, because I don't have any other alternatives. I've talked with a few folks, to include the local auto repair shop, and AAA, and they all recommend that I take it in to the dealer.
Sorry
dksob81
09-29-2005, 10:56 PM
try to unlock the passengerside door or even the liftgate door (hatch). I have this problem everyonce in awhile when I unlock my passengerdoor it doesn't disarm the alarm and when I open it it goes off and I have to try to unlock a different door.
omusogeorge
09-30-2005, 11:40 PM
I tried this. The key would not turn in the passenger side door, and I could not even get the key into the liftgate of the trunk. Just overall a bad situation and extremely frustrating.
Cam7
10-04-2005, 04:47 AM
Before getting Raped at the Dealer Try what 81 said and since you cant get the door lock to unlock take off the door pannel and move the door lock linkage manually with the Key in the lock, should have the same results.
dantesdango
10-08-2005, 04:07 PM
Turn the key in the Driver's side lock 3 times to the left, 3 times to the right, 3 times to the left, in quick succession, it will disengage the factory alarm and allow the vehicle to start. This behaavior will occur if you lock the doors before closing the drivers side door. Hope this helps!!
jeffandheidi
11-01-2005, 11:09 PM
If that doesn't work see post @ http://www.automotiveforums.com/vbulletin/showthread.php?threadid=475787&goto=newpost
It's tells what I did to disarm and disable permanently.
CrxFreak91
11-02-2005, 03:50 AM
i just fixed the same problem but i had to replace the key switches inside the door and now it starts every time. i did use the rear hatch to disable the alarm tho
jeffandheidi
11-02-2005, 08:13 AM
I tried that on mine, but that did not work... not in any door or the hatch. It sucked.
