How to remove Dash to Replace Radiomalibuss 09-25-2005, 11:18 AM I have a 1995 Dodge Ram 1500. I need to replace the radio with a factory replacement. Can someone provide me with the correct way to do this. Is there some installation details you could provide? Thanks! Craig MalibuSS@yahoo.com crazys182003 09-25-2005, 08:38 PM well not sure on the wire hookup but I can get you behind the dash and get the radio out. the way to pull your dash off is to get your fingers underneath it and pull. The dash is only held on there by snaps and when you pull it will come off. I found out the best palce to start pulling is on the drivers side underneath and to the elft of the steering wheel. I then work my way around the top of the dash and across until it is almost all the way off then I pulkl it off. Once you have it off there might be 2 screws holding it in on the faceplate. I am not sure when I got my dodge it already had an aftermarket radio in. If you are replacing a factory radio with a factory radio you should be able to just unplug the wires and plug them in the same spot on the new radio. I have dealt with aftermarket radios a little bit but haven't hooked them up. I only work with them to install amps and subs. I used to have a link to the way to change the radio but I ahd to reformat my computer and lsot all my links if I find it I will post it here again for you. Automotive Network, Inc., Copyright ©2012
