1994 Dauer 962 LeMans
price $1 200 000 USD
engine Porsche Watercooled Flat-6
position Mid Longitudinal
aspiration Twin KKK turbochargers
valvetrain Quad Cam, 4 Valves / Cyl fuel feed TAG Mototronic Fuel Injection
displacement 2994 cc / 182.7 cu in
bore 95.0 mm / 3.74 in
stroke 70.4 mm / 2.77 in
compression 9.0:1
power 544.4 kw / 730.0 bhp @ 7400 rpm
hp per litre 243.82 bhp per litre
bhp/weight 708.74 bhp per weight
torque 700.9 nm / 517.0 ft lbs @ 5000 rpm
redline 7800
drive wheels RWD w/Limited Slip Differential
body / frame Carbon Fibre / Kevlar
front brakes Brembro Ventilated Discs w/4-Piston Calipers
f brake size 330 mm / 13.0 in
rear brakes Brembro Ventilated Discs w/4-Piston Calipers
r brake size 330 mm / 13.0 in
front wheels F 45.7 x 26.7 cm / 18 x 10.5 in
rear wheels R 45.7 x 33.0 cm / 18.0 x 13 in
front tire size 285/30ZR-18
rear tire size 345/35ZR-18
f suspension Double Wishbones w/Adj Anti-Roll Bars Spring/Damper Units
r suspension Double Inverted Wishbones w/Radius Rods, Adj Anti-Roll Bars, Spring/Damper Units
weight 1030 kg / 2271 lbs
length 4650 mm / 183.1 in
width 1985 mm / 78.1 in
height 1050 mm / 41.3 in
transmission Porsche 5-Speed Manual w/Tiptronic Control, hydraulic Sinter Clutch
top speed 404.6 kph / 251.4 mph
0 - 60 mph 2.6 seconds
drag 0.31Cd
http://www.fast-autos.net/dauer/dauer962.html
