knock sensor linkhagman 09-22-2005, 08:17 PM I would like a link to purchase a knock sensor for 93 camry 3.0 Toysrme 09-22-2005, 09:09 PM www.anywhereyouwant.com Na, in all seriousness, 98% of the time the problem is in the wiring to the sensor. The sensors are nothing more than a peizo, they themselves rarely fail because they're isn't anything about them that really can fail. Replace the wiring & connectors. hagman 09-22-2005, 09:57 PM www.anywhereyouwant.com Na, in all seriousness, 98% of the time the problem is in the wiring to the sensor. The sensors are nothing more than a peizo, they themselves rarely fail because they're isn't anything about them that really can fail. Replace the wiring & connectors. Thanks and that's what I''ll try first but I have been aroud the bush on this one trying to diagnose 1) a check light that comes on when the car warms up. 2) show up as a code 52 a 3)cars does not idle properly. 4) poor gas milage 20 mpg Would bad knock sensor wiring give above symptoms Would a bad knock sensor. Hagman I have been to 8 mechanics, hours surfing the forum and net $200 worth of parts$200 worth of diagnosis to get to this point. I am ready to scrap this car which has agreat compression and everything else works great. Thanks Hagman Toysrme 09-23-2005, 04:51 PM Put everything together... ECU is detecting: 1) Fault in the knock sensor, 2) Severe knocking. Obviously it will run rich & retard ignition timing as a result of that. Take the terminal off & check that there is no continuity between the knock sensor's terminal & the body of the knock sensor. If not, it should be fine - wiring/connection is a problem somewhere. Automotive Network, Inc., Copyright ©2012
