P10 Central Locking Problemprimera man 07-28-2001, 09:27 PM Parents own a P10 and they are having problems with the central locking. As you are driving along the road all the doors will automattically lock for no reason except the drivers one. Even when you park the car in the shed etc you can come back later and the doors will be locked. This will happen nearly every time you go out. I have just taken it out myself and it done it. He's taken it to a garage and they told him it was a safety device that comes with the car...LOL (yeah right) and they put some CRC on the door locks. Anyone had this problem before ????? Cheers Here's a pic of his car Aoshi1 07-28-2001, 09:50 PM I dont have the problem with it auto locking...but my power locks work %0% of the time. Is it s fuse? P10DET 07-29-2001, 02:10 AM Originally posted by primera man Parents own a P10 and they are having problems with the central locking. As you are driving along the road all the doors will automattically lock for no reason except the drivers one. Even when you park the car in the shed etc you can come back later and the doors will be locked. This will happen nearly every time you go out. I have just taken it out myself and it done it. He's taken it to a garage and they told him it was a safety device that comes with the car...LOL (yeah right) and they put some CRC on the door locks. Anyone had this problem before ????? Yes, this is a somewhat common problem. I haven't had it, but I've read about it before. When Infinity USA had its owner's bulletin board, it was mentioned a number of times. Unfortunately, I cannot remember what the consensus was regarding a solution. I'm sorry. I know that's not all that much help other than the fact that someone should know an answer. <S> ales 07-29-2001, 02:31 AM It amy be the normal operation of the security system (if you have one). The driver's door doesn't have a factory lock motor, so I had my installed, and now when I start the car, the doors lock in about 30 seconds and open as soon as I turn off the ignition. I have not heard of the problem Geo is describing, but my second guess would be that something has been spilled onto the lock/unlock button between the seats. Third gues - the relay gone bad. I don't think there's anything else affecting the locks... Good luck primera man 07-29-2001, 02:41 AM They have not got a alarm system and have not spilled anything they know of. Thanks for the help so for guys. ales 07-29-2001, 05:05 AM I would take out the button and, after securing the wires, drive areound a bit without it. If the problem disappears - it's the button, if it persists - almost certainly the relay... P10DET 07-29-2001, 08:27 AM I believe it had something to do with the control unit. I think it was the time control unit. But, my memory is a bit fuzzy. You'd have to check the FSM's wiring diagrams to see what is controlling it. primera man 07-29-2001, 10:40 PM The car is off to Nissan this week so hopefully will get an answer back. I checked all around the wiring/relays etc and couldn't find anything :( :( ....see what they say at Nissan. Thanks again for the hlp guys. T4 Primera 07-30-2001, 10:04 AM I had a problem on my P10 T4 Primera with the locks (except drivers door) popping open all the time and couldn't lock the car. Driver's door does not have a servo, only a switch, since you always lock this door with the key as these primeras don't have keyless entry. Thats also why the central locking doesn't work when you lock the other doors as they only have servos and no switch. If you wanted keyless entry you would need to get a servo installed in the driver's door................but anyway.................... Since my locks were popping open this indicated the servos in the doors were ok.......something was telling them to open. So I pulled out the door lock switch from deep within the bowels of the drivers door and operated it both ways, then unplugged it, while checking to see if the other doors would stay locked. Still no luck! However while operating the switch, I could hear a relay clicking down under the dash. This indicated the switch was working ok so I traced the noise to the drivers side kick panel. I removed the panel and discovered a black box called the door lock timer. I unplugged the timer and found that I could now lock the doors manually and they would stay locked. NZ$65 bought a second hand door lock timer black box from Nissin' King in Hamilton and problem solved. If you ask real nice they might let you plug the box in first to see if it works (something they don't usually allow in case some other fault blows the black box). In your case the locks are operating by themselves so that indicates the servos are working and you can operate the locks from the drivers door so that indicates that the switch is working. The fact that the car locks itself after a period of time sometimes when parked or erratically when driving suggests to me that the little black box is to blame. Maybe even a loose harness plug on it. Otherwise the timer is simple to replace, just unplug the old and plug in the new. Hope this reaches you in time to avoid the Nissan workshop bill. Let us know how you get on. primera man 07-30-2001, 05:37 PM T4....Thanks dude...I've just rang him and he's going to check it out before he takes it to them. Welcome along toooo :D :D Good to see another kiwi here:D ....there's a few of us slowly getting our butts here...lol Where ya from ?? T4 Primera 07-31-2001, 05:50 AM Primera Man..........Kia Ora :D I'm in Hamilton, where are you?:confused: Hey I've got the old door lock timer I took out of our P10 here. The sticker on it says: DOOR LOCK TIMER 28451 89971 12V Niles Japan Don't Drop :thinkerg: If you like, and the numbers match up, I could sent it to you and you could try plugging it in your parents P10. If the problem they have (doors locking) turns into the problem I had (doors not locking), then I guess that would confirm that the timer is the culprit before you splash out on a replacement. As I stated earlier, a second hand replacement cost me $65 although I'd hate to think what the stealership would charge. The whole swap can be done in less than 5 minutes with nothing more than a couple of screwdrivers. primera man 07-31-2001, 07:30 AM From Palmy North. Thanks again for the help. He got back to me and said he had found something similar to what you said and he had removed the plug and given it a clean up etc and plugged it back in. Later on tonight he rang back to say it had not been doing it. Wonder if it may have been a bad terminal ???? Fingers crossed !!!:) :) T4 Primera 07-31-2001, 08:48 AM Heres hoping....:cool: T4 Primera 08-08-2001, 10:17 PM Primera man, just curious, any more trouble with your old man's door locks or is it fixed? primera man 08-09-2001, 03:47 AM Originally posted by T4 Primera Primera man, just curious, any more trouble with your old man's door locks or is it fixed? Sorry dude i should have got back to you. He's had no further trouble with it since he done the clean of the plug thing. Thanks for your help again . G20t Driver 08-11-2001, 06:05 PM I have the same problem but it did not start until after my security system stopped working. Also, my doors did not lock before the alarm went out. I can't find any blown fuses or bad wiring. T4 Primera 08-11-2001, 10:15 PM I have the same problem but it did not start until after my security system stopped working. Also, my doors did not lock before the alarm went out. I can't find any blown fuses or bad wiring. Assuming you have a factory system, and that the G20s use the same bits as the Primeras, my Haynes manual shows that the security system consists of some relays (3) piggy-backed onto the door lock timer we've been talking about. It's probably still located in the kick panel but might be on the other side in your car. I'd say thats where the problem is. Try clean up the harnesses in there if you haven't already - otherwise you may have to replace something in there. Good luck and please post what you find..... it may help others;) T4 Primera 08-11-2001, 10:23 PM I have the same problem but it did not start until after my security system stopped working. Also, my doors did not lock before the alarm went out. I can't find any blown fuses or bad wiring. Oops! :eek: Forgot to mention, if you have keyless entry you may have another unit piggy-backed onto the door lock timer control unit rather than the 3 relays. Haynes shows this system fitted to "Estate" model Primeras (Station Wagons). Unfortunately, my Haynes manual contains nothing more about these components beyond where they are located. :( G20t Driver 08-13-2001, 03:56 PM I'll check that out and post the results, thanks T4 Primera Automotive Network, Inc., Copyright ©2012
